2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,483
Losing time and money trying to use a tractor for jobs for which it isn't suited.
Totally agree, I added a fixed thumb to my 550 Ford but knew how nice articulating it would be so added some hydraulics. Works great to pick up logs or large rocks off of trailers or for loading themI believe that. I recently used an excavator for the first, and likely last time.... 3rd project would have been much easier with a thumb.
And the answer is the same too. With 200 acres you have to be careful not to get headed in the wrong direction. If you want to do it yourself look at more size: at JD310 backhoes and a 90 hp Ag tractor for the 3pt. Both can have cabs, 4wd, thumbs, grapples, and huge capability.I like the M62 for it's versatility but, with no OEM cab, I think the new ones are priced 20k too high. Good used ones are hard to come by as well.
The KX040 would be better at trail building on the hills and with a cutter, be a beast at cutting trails back and ditches. Controlled environment of the cab would be nice.
CTL has a lot of grunt and would be better on slopes than a tractor. Not as comfortable riding around but the cab would keep out the yellow jackets. No 3-point is a big drawback.
Ideally I'd have a new M62 with a mini-ex. I could by a new mini-ex and used CTL fort the cost of the new M62.
Yes, I know I'm beating the same dead horse.
I can't tow a JD310 and, ideally, I want to use whatever I get at my home 17 acres too. I've got a guy that's is suppose to be cutting in some fire breaks at the larger place which should get a lion's share of my rough road work done. Most of the rest should be closer to the pick-at-it class. I do have 3 or so acres of overgrown privet to deal with.And the answer is the same too. With 200 acres you have to be careful not to get headed in the wrong direction. If you want to do it yourself look at more size: at JD310 backhoes and a 90 hp Ag tractor for the 3pt. Both can have cabs, 4wd, thumbs, grapples, and huge capability.
With some searching you might just find older examples of both with low hours in very good condition and priced no higher than when new. I passed on a JD310E with 600 hrs. a few years back. The retired owner kept it in his garage next to the RV.
If you just want to pick at it, hire earthmovers fo do the rough work and then a M62 with or without an aftermarket cab will be just the ticket - though I prefer the M59.
rScotty
None of the TLBs have issues that I'm aware of. The 2015/16 was the model change year for M59 to M62 -a 2016 could be either.Found a low hour 2016 model. Any known issues for that year model?
