M6040 Disc size?
/ M6040 Disc size? #1
drollz
I have just purchased a m6040 w/fel 1153, fluid in my tires, 300 lbs of weight on each rear tire, and 72" box scraper with scarifiers. It will be delivered today. I was wondering what size disc would be just right for this size of tractor. I have 20 acres of mostly sandy loam. Also should I look for a pull behind or a 3-point type? Which will be better?
drollz
central valley ca.
/ M6040 Disc size? #2
I have a 5040 w/loader so we are pretty comparable. Personally I prefer a pull type disc because it typically penetrates the soil better but if you are using it in tight working areas then you will probably be better off with a 3pt hitch because it is much more manueverable. 3pt hitch discs typically don't weight as much so they generally don't dig as deep but a couple of extra passes usually makes it comparable to the pull type(at least on the soil that I am in). As far as size I am using both 8' discs(pull and 3pt) and my tractor handles it fairly easily. I would definitely get something a little wider than your tractor that way you can go along the edge of a treeline and not have to put the operator so much into the trees/brush of the field edge. At least that is my thoughts.
PALLET OF (73) 4.80/4.00-8 GOLF CARTS TIRES (A64281)
PALLET OF (73)...
JOHN DEERE 8245R TRACTOR (A64280)
JOHN DEERE 8245R...
NEW HOLLAND TS6.140 TRACTOR (A64280)
NEW HOLLAND...
2024 MAHINDRA ROXOR OFF ROAD UTV (A64280)
2024 MAHINDRA...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
2020 Solar Tech Silent Advisor S/A Solar Towable Radar Trailer (A61572)
2020 Solar Tech...
