Tractor Sizing M59 VS full size backhoe.
   / M59 VS full size backhoe. #11
I do a lot of this work and can tell you for the variety of mixed jobs the M59 is a lot better choice. Rarely do I need to call in a larger backhoe than my 110 and the M59 will work faster too. I hired a 20 ton excavator today for a job bigger than I would take on with my 110. Don't need to own everything.
   / M59 VS full size backhoe. #12
How would a full sized backhoe, or a M59, compare to a farm tractor with a hoe attachment. A strong attachment like a woods BH90x?
I would think buying an attachment would be like spending 10k on a toy. Comparatively speaking.
   / M59 VS full size backhoe. #13
I would buy the tractor and skip the backhoe for it with what they cost. If you are just dabbling as you say, id either rent a small excavator or backhoe. Or possibly even buy a used backhoe or excavator down the rd.
   / M59 VS full size backhoe. #14
Because it's more manageable to move around. The single biggest reason is loosing the SSQA on the front. If I didn't care about the grapple option I'd have a full size and never think twice.
Every brand has a version with a removable front bucket. Most of them call it a tool carrier. You can remove the bucket and attach a grapple, pallet forks or even a hay fork. I modified my 555E to a quick attach so I could have a grapple. I can't think of nothing more useful for land clearing then a backhoe to dig out the trees, and then the grapple to pick them up and put them on the burn pile.
   / M59 VS full size backhoe. #15
So based on this statement, you won't need to do any 3pt work. You just want a smaller than full size TLB.
Not even close. I had a Kubota BH90 and the M59 backhoe is about 3 times as strong and the loader is more than twice as strong. A full size is quite a bit stronger than the M59.
I'm thinking this is where I'm at. A M59 is going to take the whole budget by itself assuming I even find one that cheap. I could spend 15-20k on the full sized and have some money left to convert the front and buy a grapple.
   / M59 VS full size backhoe. #18
I think that is a wise decision. Now to find a good used full sized hoe.
   / M59 VS full size backhoe. #19
A M59 needs the BH plus 1/2 full loaded rears to fully use the bucket. Too light otherwise. A full size TLB is like a really big Swiss army knife that does not fit in your pocket. That is why machines like the M59 cost near as much as a full size TLB
Also, that is why excavators and skid steers are so popular on larger job sites, as the may not be Swiss army knives, but do what they do very well.
   / M59 VS full size backhoe. #20
I have two TLBs for the past 4 years now, so ask away. There's an M59 and a JD310SG. These are not used for commercial work; they are both just used on our mountain property in Colorado and for helping with occasional chores for neighbors. We are still rebuilding & landscaping from a 500 year flood that swept across our land in 2013. It completely reshaped the land, moved the creek, filled in the pond, and left a mountain of debris and boulders. There has been more than enough work for two machines. At first we did a lot of hiring bulldozer & excavator time..
Both are turbo diesels, and everything works as it should. The M59 has a thumb, but no extra weights or tire fill. The JD310SG has a cab with every comfort, an extendahoe, and extra weights. Both machines are in extra good condition with good tread.
The machines are parked side by side, and we simply use the one that fits the job. Sometimes that means using one's backhoe to fill the other's loader bucket. It's been fun - sort of a dream come true to be able to choose which one of two such excellent machines to use each day. Tractors and machinery are long-time hobbies of mine. Along with tractors, I enjoy welding, machining, and generally tinkering on things.
The machines are both good TLBs, but they do have different strengths. Some of the differences are things that will surprise you after you use both for awhile.
What are you wanting to compare?
enjoy,
rScotty
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
ALLISON TRANSMISSION (A55745)
ALLISON...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A55315)
2012 Ford F-150...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A57880)
2018 INTERNATIONAL...
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
