M59 hydraulics got slow and weak.
   / M59 hydraulics got slow and weak. #41
Ok, back from taking machine to dealer. I talked to the guy who talked with kubota. He said they had a few that had to have both pumps replaced.
And as of now they are fixing my machine, working up a price for me to to trade mine for the brand new one and pricing an extended warranty for mine. Not sure I want another 08. If it was an 09 or 10 I might.
This is an active forum for M59 owners and I haven't heard of any pump problems. Anyone else? Did you get any more info?
Traditionally tractors go by the serial number rather than year. So their year is the year that they are sold, not manufactured. That means its possible that an '09, 10, or 11 could be an earlier model than one sold in '08 by another dealer. The serial number will tell you more.
good luck. Please keep us posted.
rScotty
Update is talked to service guy and said parts are ordered, should be here wed. 2 pumps and other stuff kubota said needed to be changed when this happens. So fingers crossed. One thing I'm curious about is if there are updated part numbers, like pumps..etc
Dealer has it apart, waiting for 1 more pump. Asked what could have made both pumps out and he said they were discussing it this morning. Only conclusion is it just got hot. I dig wide open for hours at a time. Anyways I said I want to go back with super udt even if kubota won't pay for it I will pay the extra. Not sure it's the answer but it can't hurt. I run it hard but not like an idiot, I stay onto on all maintenance. Changed hydro fluid and filters for first 50. Anyways I suffer from impatience and just want to know if this will happen again. It's a great machine. Does anyone else here dig ditches with theirs? What rpm do you run? I dig at 2500rpms.
   / M59 hydraulics got slow and weak. #44
You might want to consider an extra oil cooler. Heat is a killer of hydraulics. Just for interest if you have an infrared thermometer, check the temp of the hydraulics when you have been using it for a while. If you are over 140* it is too hot.
I do have one. Is there a specific add on cooler for these? Where is a good place to monitor temp? The motor mounted one will be hotter cause of motor heat.
   / M59 hydraulics got slow and weak. #46
Anywhere on the main transmission case would be a good place to check after an hour or so of running. I don't know what Kubota puts on your unit but you could double up coolers or just replace the stock one with a high efficiency cooler. Most these units have undersized coolers for steady work in my opinion.
   / M59 hydraulics got slow and weak. #47
So they think it was a heat problem? Well, I guess I don't find that too surprising.
In the operating manual, Kubota clearly states that the backhoe is rated for operation at full rated RPM (2700). There aren't any cautions about how long or how hard to work it at that RPM. So it sounds to me like you were operating within the rating even for hours at a time. Except it sure didn't work out.
We've got a pretty active group of M59 owners here on tractorbynet, and this is the first that any pump problems have been mentioned.
Somehow yours got too hot. But how? Well, how about some speculation? Of course the the pumps could have been badly manufactured. Mistakes do happen without fault or blame. Since no other M59 owners have reported problems with the then that's probably it. It's also possible - though less likely - that Kubota misfigured the heating/cooling capacity of their hydraulic system. Frankly, speaking as an older and senior mechanical engineer I doubt that's the cause. Designing for heat transfer is basic and well understood. And not only would they have to miss some basic calculations, but the standard heat rise tests every company does during product development would also have had to be ignored.
So if a system isn't creating too much heat, then the problem would have to be that it isn't getting rid of the heat generated by normal operation. There could be a plugged cooling loop somewhere. I haven't even looked to see where the cooling loops are in that system but you can bet that it has them. Even more rare would be if something happened to reduce the coefficient of heat transfer of the hydraulic fluid itself. That would be pretty far out in left field, but would sure cause the same problem. It would have to be something like a specialized hydraulic fluid designed for low ambient temperatures. Again, not likely.
Either way, if it had happened to my M59 I'd be taking the time to find out what temperature Kubota wants their hydrualic system to operate at, and putting a temperature gauge in the hydraulic circuit. Any shop can do that. In fact I might do thaton my machine anyway. No point in repeating a repair.
What else...Oh, you asked what kind of digging other M59s do. I use it on our land instead of commercially like you do. But that wouldn't stop me from taking a commercial job if one came up. And I'd expect the machine to do its part without complaint. At home I tend to dig at 50/60% of rated RPM. On a job, I'd probably run it faster.
Good luck and thanks for keeping us posted
rScotty
Update:
Was gonna pick it up but said they had a leak on suction line after installing the two pumps and stuff. Could the suction line have been the problem from start? Fluid is picked up from one place, right, so that could explain both pumps being weak. I don't know... I've borrowed my buddies kubota kx and rented a new holland mini ex, the size was a 26. It was nice but no suspension seat. Ouch. Whatever...said maybe ready ready tomorrow mid morning....2 pumps..how
   / M59 hydraulics got slow and weak. #49
If the suction side had a air leak that would allow it to suck dirty air in to the fluid and it would not get filtered.
As for my b26 I run it wide open for days at a time doing work. Last summer had a project 3 days 100 degrees out at a grain elevator you dont get any hotter than that.
Ok, got it today. Have complete order sheet showing all parts and labor if anyone is interested. Both pumps, other parts like o rings, super udt..etc to the tune of $2400. I had to pay $100 dollars cause I didn't purchase machine there which I thought was bs. I was sent home with 4 hydraulic filters and 2 hat filters to be changed in 25 hr an 50 hours from now. Gave me 3/4 jug of a 2.5 gallon jug os sudt. I measured and filter changes take 6 gal. Wt(poop)? Anyways they had sudt2 so I bought 15 gallons at the tune of $385 that I plan to use at the 50hr change. Dug, pushed and backfilled for an hour and all seems well. I can't turn the steering wheel left to right at idle on hard dirt and the main boom will not lift at all if bucket is curling full open.( paranoid?) seem to dig with a little better power at lower rpms, 2200. When picked up I crawled under it to check pump out, it was dripping with oil. Wiped it clean and checked after running for hour.. Just a little, no drips just kinda 'perspiring'. Will keep eye on. Seems like very good install.
   / M59 hydraulics got slow and weak. #51
.....I can't turn the steering wheel left to right at idle on hard dirt and the main boom will not lift at all if bucket is curling full open.( paranoid?) .....
Are you saying that you can't lift the main boom and curl the backhoe bucket to the full open position at the same time? Or are you saying you cant lift the main boom if the bucket is in the full open position?
-mark
Basically the bucket curling takes precedence over the main boom cylinder. Would love to know if others have this. With boom down like in a ditch if you push levers for full bucket curl and full boom lift, the boom will not lift until you let off the bucket curling. I noticed it when pulling boom out of ditch to go dump. I'm sure it is normal because of the flow patterns, But would be grateful if others would check theirs.
   / M59 hydraulics got slow and weak. #53
Mine does that too. If I'm not mistaken, there are two pumps for the backhoe, one for swing and other for the curl, crowd and boom functions. You can swing and do any other function at the same time, but you can only do one curl, crowd or boom function at a time.
Regarding steering, I can turn lock to lock at idle on any surface, mud, hard dirt asphalt, concrete...no problem.
-Mark
Yea, the steering is got me troubled. Could be air in lines.
Steering is fine now, but have very small leak at bottom pump.keep wiping it clean and get a drop on ground overnight. Poop
   / M59 hydraulics got slow and weak. #56
How is it doing today? Let me know what you would like me to check against my M59 as I'll have it out working this weekend. They sure are a handy size tractor. We sure like ours and try to treat it right.
Have you got SUDT2 in it now? Think twice. The old SUDT oil didn't do well in our M59.....foamed, squealed, and just didn't have the power of a standard grade hydraulic oil. Then the backhoe cylinders started jerking and sticking. Ended up costing me some real bucks. That doesn't mean that it wasn't just a case of incompatibility with my particular tractor and the SUDT - I've heard that Kubota doesn't make those backhoe cylinders, and it's common knowledge that Kubota doesn't make the SUDT themselves. Maybe the guys they sub stuff out to should get together.
rScotty
Right now it has sudt. Maybe they had a problem with it and is why they went to the sudt2. The only scenario we could come up with is my fluid got hot and stopped working propeerly. No other reason 2 pumps should go.
I think they tried to accommodate use in cold weather with sudt so maybe it runs even thinner causing the lack of power. This sudt2 is full synthetic I believe so maybe it's better. I hope.
rScotty
It runs good, seems like it has good power. If you think about it when using yours drop you boom and then go full curl and full boom lift and see if curl takes all the power. I think it's first in the system and robs the flow of pressure.
Heading to shop Monday to get the lower pump drip fixed.
   / M59 hydraulics got slow and weak. #60
Yes, I checked mine yesterday. Mine does just as yours does....that is, the bucket curl has precedence over the boom lift. The boom won't lift as long as it is curling. Are there any other moves like that? Do other backhoes do that? I don't think it does the same thing when pushing the boom down and curling...but now realize that I don't know what it does. Sort of like typing, working the backhoe is instinctive (now that I've reversed the thumb lever) and when I'm not working it I couldn't tell you which lever does what.
good luck, rScotty
2014 Nissan Murano SUV (A59231)
2014 Nissan Murano...
2018 Deere 323E (A53317)
2018 Deere 323E...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
