M59 hydraulics got slow and weak.
   / M59 hydraulics got slow and weak. #101
Yes. Sorry to the thread.
I used same dealer. They changed more releif valves, put gauges on and adjusted adjustable releif valves to maximum pressure. Bottom line, it runs and works good but this little machine suffers from heat. I have not used it much for my business because I have gotten very busy and started sub contracting the digging. So no long digs with it since last dealer trip. I just use it for mixing feed/mineral in front bucket for cows. It's perfect for that. I think I will go back to full size backhoe for work.
Darn. Well, I'm sorry to hear that's the upshot but sure do thank you for the update. One last question or two... Do you think yours is any different from other M59s? Or is what you are seeing just the limitation of the model?
And you've made me wonder if the backhoe temperature limitation is nothing more than the size of the oil cooling radiator?? The Kubota radiator looks big enough physically, but I also know that as an engineer I've watched in amazement for 40 years now as one foreign manufacturer after another repeats the same mistake on machines built for export to the US. Each one seems to have to learn all by themselves that they need to increase the cooling capacity on machines they send over here. I'm not exactly sure as to why.
Anyway, I've already said that I never have considered our M59 to be a real commercial/industrial duty TBL in the same league as the various makes of yellow industrial Cases, Cats, Fords, and JDs we see everyday on job sites. Frankly, I looked for one of those makes in the under 70hp & less than 9000 lbs. size and couldn't find it. Apparently nobody but Kubota & JD builds one. Naturally enough, the Kubota isn't built like a Case or Cat. For that matter, it isn't as quiet either. But all and all it is a better compromise for my work. It sure is a more handy machine with plenty of power and speed for my non-commercial uses. I can't help wondering if the differences between M59s we keep running into are nothing more than all of us us using the machines to nearly their full capacity in a different type of ground? Around here in the Rockies, I find myself needing the M59's strength and handy small size more than it's cycle speed. So I work mine hard, but get to run it at fairly low RPM. Or maybe that's just a difference in the jobs.
Good Luck,
rScotty
   / M59 hydraulics got slow and weak. #102
I just spent the past three days digging with the M59 here on my place in Colorado. I have been working at 1800-2000 RPM. The backhoe has plenty of power, except for the swing. "Slow and weak" is exactly right for the swing. I can manage for what I need to do but it would be too slow for production purposes. In some cases, e.g. when I could only use one stabilizer and the hoe was not level, it could barely swing the hoe slightly uphill against its own weight. Plenty of power for everything else, it is only the backhoe swing which is an issue on mine. I agree though, that for one machine which does it all there is nothing better out there currently.
We theorized earlier that it could be an issue with lube for the main swing bearings. It's not conclusive yet, but I am making progress getting some high pressure synthetic red moly grease in there - the lower bearing is pretty much ok now, still hard to get grease into the top one. But I doubt if this is the problem. I'll have to take a more careful look at the swing circuit eventually when I have the hoe off.
   / M59 hydraulics got slow and weak. #103
SNIP
We theorized earlier that it could be an issue with lube for the main swing bearings. It's not conclusive yet, but I am making progress getting some high pressure synthetic red moly grease in there.
Hello TbarD, glad to hear that you are getting some seat time in. It's a nice summer to be in Colorado. And glad to hear that the M59 is treating you well.
This thread has been an education for me. One of the things I wonder is if all our M59s work about the same and the difference is just in expectations? Or is there a real difference in the swings?
I think my swing strength and rate is about right for our machine; others could use more. But is the difference real or perception? I wonder if there is a simple way to compare swings? The Operator's Manual for the Kubota BT1200 Backhoe says to run the hoe with the engine at between 75% and full rated RPM after the oil is up to temperature... and to run at 50% before then. Frankly I run mine at about 50% or maybe less most of the time. The manual also says that swing cycle time is 2.1 seconds measured from 90 degrees to center. I'll measure mine if I can figure out an easy way to do it.
Talking about swing rate I've got to give Kubota credit for their swing protection circuit that causes the swing movement to suddenly and automatically slows down as it approaches the limit to either side. Some sort of anti-slam valve is being progressively actuated is what it feels like. For the last few degrees it is barely moving.... Very convenient and helpful. That's got to be why Kubota measures swing cycle time from 90 out towards center instead of the other direction.
I probably use the swing function to side sweep material out of the way more than I should. Our M59 will push hard enough to make me begin to worry about just how wise it is to put that much side stress on the backhoe. Then again, it could be I worry about stuff like that more than I should. More specifically, on the level it easily slides a rock the size of a suitcase or moves a pile of dirt and rocks about equal to what is held in a full bucket (18 or 24"). Ok, I admit that side-sweeping will do a bit more work than that, but I don't think it will budge a load twice that size unless I "thwop" it with some sweep speed - and doing that has got to be true backhoe abuse. Maybe that's about all that any of them will do? I wouldn't want mine to do more. Unloaded, it will swing fast enough to shake the tractor when it stops.
Getting lube into the swing platform zerks was a problem with mine. There are lots of zerks, and I had to use the hoe to sort of push on itself in different directions until it took lube. I was concerned because the swing movement would groan and screech and the regular tanslucent grease I use on the boom and bucket pivots just didn't make any difference even when I was successful in getting it into the swing bearings. When regular grease didn't work I searched until I found some ugly black and nasty high percentage Moly grease. BINGO! That fixed it in one cycle. The thing I hate about Hi-Moly greases is how they can stain almost everything that they touch with a permanent black mark. If not super careful, I find stains everywhere from gloves and tools to upholstery. But what I wanted was the specific way that moly lubricates differently from oil-based greases. Moly is expensive stuff....I think I paid somewhere around $15/20 tube. Here's a link that talks about why it's worthwhile to use for high pressures:
"MOLY" THE SUPER LUBRICANT
Or take a look at McMaster-Carr
Have fun out there,
rScotty
This last time kubota corp and the rep were in on it. Kubota assured the dealer hydraulic temps over 180f are normal. I just don't think sustained heat like that is good. I am going to look into a bigger cooler. Another thing, once when I was changing filters without complet drain down I caught fluid in buckets. When I filled it back up I used a big clear plastic pitcher to pour oil back in. The oil was kinda milky but not with water, it was air tiny air bubbles. That's no good. Anybody else notice this?
Rscotty I have seen you post on fluids, you seem to like new holland right? Wonder if all fluids are created equally? I am using the sudt2 now. Maybe some fluids release air better than others. The more air, the weaker the hydraulics and the more heat you generate. I was assured that the if the suction had a leak the tool the dealer used would have found it.
Another thing is the quick disconnects on the backhoe. I don't like having them and am taking them off. It doesn't seem good for a high flow attachment.
So today I took the pioneer fittings off. You do not need any fitting to do this just take hose loose from control valve so it can rotate. You have a 1/2" return line that catches the fluid from a 3/8" boom swing line, and 1/2" line that supply's the rest of backhoe. Bad ideal. Working multiple cylinders will over power the restricted return fitting.
   / M59 hydraulics got slow and weak. #107
Rscotty I have seen you post on fluids, you seem to like new holland oil, right?
Hershey, it's the tractor that seems to have a preference; not me!
Yeah, I've posted on the oil and the temperature before. And yes, I saw that same foaming in my SUDT too. Take a look at message #56 in this thread. But keep in mind that was the old SUDT, not the SUDT2. I swapped oils about a month before the SUDT2 came out....sigh... Still, I'm happy to stick with the New Holland GL134 for now.
Sounds like you got some interesting info from the Kubota rep regarding the hydraulic oil temperature. I'm thinking that the reps need to get with the guys who wrote the specs for the shop manual and decide what number they want to use. The shop manual is pretty specific about 140F as the upper temperature.
I agree on the quick disconnects. If you don't use them, why have the restriction on flow?
I'm editing this long post I did in the hopes that we can keep this thread more focused. The M59 is a top of the line model, so naturally expectations are high. As we discuss improvements, I don't want to lose sight of the fact that it is a very good machine just as it is. And as I read through these posts it obvious that Kubota has been supportive too.
It's all good, rScotty
   / M59 hydraulics got slow and weak. #108
The two reasons I would not consider buying Kubota again are:
1. Part prices. Kubota is just too greedy.
2. Warrantee, Too often Kubota just does not step up in behalf of their customer.
Imagine the good faith Kubota would get just replacing the entire machine.
Kubota could then do some real failure analysis to improve their product.
Once Kubota fixes it they could donate the returned machine to a worthy organization (Like Me!).
Advertise this and self promote what a great company they are, telling the whole story truthfully, and write tit off to advertising. Everybody wins.
1.) Sure glad I own an L39 vs the M59.
I can work it to death, never had a heating loss of hydraulic problem. For a 10' hoe, it is a beast in all functions. Slow digger, but so are other TLB's and the controls are not pilot ( I own an Komatsu excavator and am spoiled by the speed an fine control's. ) The L39 could use the curl cylinders, 45 HP Motor, and front axle from the L45, but otherwise a strong machine. for its size.
2. I sure do agree with your statement. As much as I think Kubota's are generally fine machines, Kubota could use a lesson form some of the better car manufactures about customer service & support.
PS
Put Royal purple in it at the 400 hr service. Almost 1300 hrs later, same oil, just change filters.
   / M59 hydraulics got slow and weak. #109
Have fun out there,
rScotty
Pound for pound, the L39 has more swing force than my excavator. I use the hoe almost as much to get unstuck or lift it to positon the machine as I do to dig. I would say the weakest function of the hoe is the dipper force, and it really is not bad.
About Grease. I wish figured this out earlier. My bucket linkages are worn out. I've changed the pins and bushing, but the links themselves are not bushed, have minimal load bearing area, and are priced the Kubota way, making them an expensive proposition to replace.
Grease the bucket linkages every 3 hours in heavy engagement work!. The manual says grease the loader every 10 hours. The other joints of the loader are not critical. Grease every 10-15 hours, but those bucket joits, grease the heck out of them.
Same goes for the hoe.
I like the Komatsu grease. It does not contain Moly, but is miseralbly tacky. Tacky in a good way. Pumps nice, stays put better than most other greases and is cheap at less than $3.50 a tube. I figure if it is what is used on a million dollar excavator, it works good on my tired old iron.
   / M59 hydraulics got slow and weak. #110
Yes, I checked mine yesterday. Mine does just as yours does....that is, the bucket curl has precedence over the boom lift. The boom won't lift as long as it is curling. Are there any other moves like that? Do other backhoes do that? I don't think it does the same thing when pushing the boom down and curling...but now realize that I don't know what it does. Sort of like typing, working the backhoe is instinctive (now that I've reversed the thumb lever) and when I'm not working it I couldn't tell you which lever does what.
good luck, rScotty
I have al ot of seat time: about 1,100 hours on my grey maket excavator and over 1,600 hours on my L39.
On the L39, it behaves similar, but you can lift the boom curl and pull in on the dipper all at once. Doing this smothly is a lot more difficult with the L39 than on an excavator with pilot controls, but I've also run other small TLB's and they are terrible. Really terrible. The small cheaper hoes are the worst, really jerky and single function. By comparision, I would imagine the M59 is reasonaly smooth in operation to any other non industrial TLB.
I am suprised by the heating and foaming problems of the M59 on this thread.
Tanker Trailer (A59230)
Tanker Trailer...
2019 CAT 259D (A60462)
1762 (A58375)
1762 (A58375)
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
3-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
3-Gang Reel Mower...
