M59 hydraulics got slow and weak.
   / M59 hydraulics got slow and weak. #41
Ok, back from taking machine to dealer. I talked to the guy who talked with kubota. He said they had a few that had to have both pumps replaced.
And as of now they are fixing my machine, working up a price for me to to trade mine for the brand new one and pricing an extended warranty for mine. Not sure I want another 08. If it was an 09 or 10 I might.
This is an active forum for M59 owners and I haven't heard of any pump problems. Anyone else? Did you get any more info?
Traditionally tractors go by the serial number rather than year. So their year is the year that they are sold, not manufactured. That means its possible that an '09, 10, or 11 could be an earlier model than one sold in '08 by another dealer. The serial number will tell you more.
good luck. Please keep us posted.
rScotty
Update is talked to service guy and said parts are ordered, should be here wed. 2 pumps and other stuff kubota said needed to be changed when this happens. So fingers crossed. One thing I'm curious about is if there are updated part numbers, like pumps..etc
Dealer has it apart, waiting for 1 more pump. Asked what could have made both pumps out and he said they were discussing it this morning. Only conclusion is it just got hot. I dig wide open for hours at a time. Anyways I said I want to go back with super udt even if kubota won't pay for it I will pay the extra. Not sure it's the answer but it can't hurt. I run it hard but not like an idiot, I stay onto on all maintenance. Changed hydro fluid and filters for first 50. Anyways I suffer from impatience and just want to know if this will happen again. It's a great machine. Does anyone else here dig ditches with theirs? What rpm do you run? I dig at 2500rpms.
   / M59 hydraulics got slow and weak. #44
You might want to consider an extra oil cooler. Heat is a killer of hydraulics. Just for interest if you have an infrared thermometer, check the temp of the hydraulics when you have been using it for a while. If you are over 140* it is too hot.
I do have one. Is there a specific add on cooler for these? Where is a good place to monitor temp? The motor mounted one will be hotter cause of motor heat.
   / M59 hydraulics got slow and weak. #46
Anywhere on the main transmission case would be a good place to check after an hour or so of running. I don't know what Kubota puts on your unit but you could double up coolers or just replace the stock one with a high efficiency cooler. Most these units have undersized coolers for steady work in my opinion.
   / M59 hydraulics got slow and weak. #47
So they think it was a heat problem? Well, I guess I don't find that too surprising.
In the operating manual, Kubota clearly states that the backhoe is rated for operation at full rated RPM (2700). There aren't any cautions about how long or how hard to work it at that RPM. So it sounds to me like you were operating within the rating even for hours at a time. Except it sure didn't work out.
We've got a pretty active group of M59 owners here on tractorbynet, and this is the first that any pump problems have been mentioned.
Somehow yours got too hot. But how? Well, how about some speculation? Of course the the pumps could have been badly manufactured. Mistakes do happen without fault or blame. Since no other M59 owners have reported problems with the then that's probably it. It's also possible - though less likely - that Kubota misfigured the heating/cooling capacity of their hydraulic system. Frankly, speaking as an older and senior mechanical engineer I doubt that's the cause. Designing for heat transfer is basic and well understood. And not only would they have to miss some basic calculations, but the standard heat rise tests every company does during product development would also have had to be ignored.
So if a system isn't creating too much heat, then the problem would have to be that it isn't getting rid of the heat generated by normal operation. There could be a plugged cooling loop somewhere. I haven't even looked to see where the cooling loops are in that system but you can bet that it has them. Even more rare would be if something happened to reduce the coefficient of heat transfer of the hydraulic fluid itself. That would be pretty far out in left field, but would sure cause the same problem. It would have to be something like a specialized hydraulic fluid designed for low ambient temperatures. Again, not likely.
Either way, if it had happened to my M59 I'd be taking the time to find out what temperature Kubota wants their hydrualic system to operate at, and putting a temperature gauge in the hydraulic circuit. Any shop can do that. In fact I might do thaton my machine anyway. No point in repeating a repair.
What else...Oh, you asked what kind of digging other M59s do. I use it on our land instead of commercially like you do. But that wouldn't stop me from taking a commercial job if one came up. And I'd expect the machine to do its part without complaint. At home I tend to dig at 50/60% of rated RPM. On a job, I'd probably run it faster.
Good luck and thanks for keeping us posted
rScotty
Update:
Was gonna pick it up but said they had a leak on suction line after installing the two pumps and stuff. Could the suction line have been the problem from start? Fluid is picked up from one place, right, so that could explain both pumps being weak. I don't know... I've borrowed my buddies kubota kx and rented a new holland mini ex, the size was a 26. It was nice but no suspension seat. Ouch. Whatever...said maybe ready ready tomorrow mid morning....2 pumps..how
   / M59 hydraulics got slow and weak. #49
If the suction side had a air leak that would allow it to suck dirty air in to the fluid and it would not get filtered.
As for my b26 I run it wide open for days at a time doing work. Last summer had a project 3 days 100 degrees out at a grain elevator you dont get any hotter than that.
Ok, got it today. Have complete order sheet showing all parts and labor if anyone is interested. Both pumps, other parts like o rings, super udt..etc to the tune of $2400. I had to pay $100 dollars cause I didn't purchase machine there which I thought was bs. I was sent home with 4 hydraulic filters and 2 hat filters to be changed in 25 hr an 50 hours from now. Gave me 3/4 jug of a 2.5 gallon jug os sudt. I measured and filter changes take 6 gal. Wt(poop)? Anyways they had sudt2 so I bought 15 gallons at the tune of $385 that I plan to use at the 50hr change. Dug, pushed and backfilled for an hour and all seems well. I can't turn the steering wheel left to right at idle on hard dirt and the main boom will not lift at all if bucket is curling full open.( paranoid?) seem to dig with a little better power at lower rpms, 2200. When picked up I crawled under it to check pump out, it was dripping with oil. Wiped it clean and checked after running for hour.. Just a little, no drips just kinda 'perspiring'. Will keep eye on. Seems like very good install.
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
Eagle Weathervane (A55853)
Eagle Weathervane...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 MACK P164T (A58214)
2020 MACK P164T...
Case Titan 3530 (A56438)
Case Titan 3530...
