M59 Discussion Thread
/ M59 Discussion Thread #421
The L39 relief is supposedly set at 2750 Psi, mine was set low. Bet the M59 is 2700 Psi or so.
M62 $$$$$
/ M59 Discussion Thread #422
Main hydraulic circuit relief valve setting 2780 to 2910 psi
/ M59 Discussion Thread #423
Thanks Mike and Mike.
Now, does anyone have the ground clearance handy? The specs show the ground clearance of the tractor itself, but don't seem to account for the loader frame.
I'd like to compare it to my ground clearance on my 4610.
I'll stop asking questions now.
/ M59 Discussion Thread #424
I got a question!
Why are you interested in an M59 when you have a very capable Ag. tractor in the L4610 and a beast TLB with the JD410 TLB. Is it weight limitation, transport, soft ground?
/ M59 Discussion Thread #425
I got a question!
Well, I could make a whole new thread on that subject, but to avoid taking this discussion too far off topic, the main points are transporting the 410, as well as it being too large for most of the work I'm doing with my business. The only time we ever use the 410 anymore is for parking lot snow removal/management in large storms, and for lifting when the 4610 is maxed out.
I actually don't really need a backhoe at all, I came close to buying a used one without the backhoe a few months back, but ultimately decided "it would be nice to have." Realistically though, I'm still a ways from biting the bullet on one regardless. I think there is a good chance the M62 might be the replacement for both the 410 and my tractor after it's been out a year or two, depending on the factory cab.
I waffle back and forth between keeping my tractor and buying a skidsteer, or replacing it with a more capable tractor. The main determining factor for me is all my implements I currently have would be matched perfectly with the M59, aside from the stumpgrinder which really could use 50+ PTO hp but it would at least work better than my current 39. The stumpgrinder is one of my better money makers.
/ M59 Discussion Thread #426
I don't see anything about ground clearance in the manuals, so I went out and looked at the tractors themselves - both our M59 and our JD310SG. BTW, for those who don't know John Deeres, the JD310 is that well-known common yellow construction backhoe/loader tractor that you see on most construction projects. It's 90 to 100 hp and weighs somewhere in the 16 to 18,000 lb range. With 4x4, a cab with heat/AC, comfort-ride and extendahoe...... a good five year old low hour 310/410 costs about the same as a new M59.
Back to ground clearance, there's never been a ground clearance problem anywhere with the John Deere. It's got plenty.
The M59 doesn't have as much.
On the M59, clearance is not a problem under the tranny, under the axles, or beneath the loader rails, .....but I'm thinking you'll notice a lack of ground clearance on the back hoe support if you back up over a pile of rocks to use the backhoe. When backing up over broken ground the part that bottoms out first is the bottom of the backhoe support. Specifically it's the lower support collar on the boom swing pivot. That part is about 9" off the ground on the M59 and the same measurement is about 13" on the JD.
The good news is that bottom boom pivot is a pretty heavy piece of steel on both tractors, so it doesn't hurt anything to slide up on it nice and slowly. Sometimes on the M59 I'll even deliberately slide the tractor up on a rock and then use the outriggers to lift it free. But I have to mention it because clearance right there is a limitation on the M59. It would be nice if it were a few inches higher. Of course then the hoe would lose the same number of inches in digging depth. Frankly making that change wouldn't bother me much. I rarely dig full depth, but often need to back up into a rock pile to do some landscaping with the thumb. We probably use the thumb for placing things as much or more than we use the bucket for digging.
It's just a guess, but we might be using the M59 ten hours for every one hour we use the JD310. That's nothing against the 310 - it's a classic. But the M59 is plenty strong, moves nearly as much material, and it's just nicer to use. Sort of like doing a job wearing gloves versus mittens.
luck, rScotty
/ M59 Discussion Thread #427
Do any of you M59 owners have a service manual? If so, would you be so kind as to look up the hydraulic pressure that the M59 puts out for implements? I've tried finding this online but only seem to come up with the hydraulic flow of 16gpm, but can't find the pressure anywhere, and without both numbers, it's hard to really figure anything out regarding hydraulic power available to run implements.
Also, anyone have any secret information about the M59's replacement? The M62.
An Important bit of info for the m62- NO AC!
/ M59 Discussion Thread #428
I think that would be a deal breaker at this level...
/ M59 Discussion Thread #429
luck, rScotty
Back just a few years ago it seems when I was carving our farm out of a blasted piece of NH Ledge, I debated between an excavator vs. a commercial TLB to spare my undersized and overwhelmed L39 from some of the brutal tasks at hand.
Although the commercial strength FEL of a construction full size TLB and the ability to transport itself and move spoils over a distance would have been nice, the Excavator filled the bigger machine requirement better, now that i look back upon it.
As strong as a full size TLB, the excavator digs just faster, The Thumb and 360 swing can pick and move object better within its swing circle, An excavator is more maneuverable, and does less ground damage with better traction. Full size TLBs do not do well on muddy ground. The dozer blade grades and pushes material at least as well as a big backhoe bucket.
For moving spoils I still had the L39, and if a rock or other object was to large for the L39, I 'd host it up on the dozer blade, praying I could hold it in place with the bucket and thumb and not have a several ton rock bash me or the cab, then crawl it to its final resting place. In the woods the excavator was at least as nimble as the L39, and a much better logger. An excavator is a better crane than an older full size TLB, I understand the new TLBs have boosted their lift capacities.
I’m not discounting the versatility of a full size TLB on a construction site, but on raw land and farm use, I can see why a machine like an exvator and/or a lighter TLB like the M59/M62 would be a better choice. I still find it hard to swallow that an M59 new costs as much as a good used late model low hour full size TLB!
/ M59 Discussion Thread #430
luck, rScotty
Although the commercial strength FEL of a construction full size TLB and the ability to transport itself and move spoils over a distance would have been nice, the Excavator filled the bigger machine requirement better, now that I look back upon it.
For moving spoils I still had the L39, and if a rock or other object was to large for the L39, I'd host it up on the dozer blade, praying I could hold it in place with the bucket and thumb and not have a several ton rock bash me or the cab, then crawl it to its final resting place. In the woods the excavator was at least as nimble as the L39, and a much better logger. An excavator is a better crane than an older full size TLB, I understand the new TLBs have boosted their lift capacities.
I'm not discounting the versatility of a full size TLB on a construction site, but on raw land and farm use, I can see why a machine like an exvator and/or a lighter TLB like the M59/M62 would be a better choice. I still find it hard to swallow that an M59 new costs as much as a good used late model low hour full size TLB!
/ M59 Discussion Thread #431
I was going to post this in the new M62 thread but figured there were more owners here.
I have a question regarding size.
Is the M59/62 physically any bigger than the L5740? I know the framework for the FEL is larger, more substantial, and same with the backhoe mount, but is the actual size of the tractor itself, any different from the 5740?
I've looked at the specs on tractordata, and it is difficult to tell because the dimensions and weights for the M59 is listed with the loader and backhoe attached, vs the tractor only weight for the 5740.
I'm wondering if the difference is just the extra steel on the FEL and backhoe that make up the differences, or, if it is a completely different frame altogether????
/ M59 Discussion Thread #432
Does anyone use their M59 as a tractor/loader only? How is it using all the other normal 3 point hitch implements? I'm sure you'd need to weight the tires, but I'd assume it's not much different than a regular tractor right?
/ M59 Discussion Thread #433
Except that you will need to load the tires and add 1200-1500 lbs as counter weight to the 3 Pt.
With your L4610 and a big ole albatross of a Deere 410, I can not see the need for a M59 or M62TL at all. I'd stick some bigger cylinders on the 4610, and if you have need for another toy, a used CTL, larger Mini Ex with thumb and blade or an RTV to scoot around in would round out your stable much better than the M59.
Ift you are going to trade the 410, you will miss having a TLB. I bet less than 5% of B26, L39/45, M59/62 are sold without a Hoe. in 11 years, I never removed the hoe on my L39 and I don't see the need in the future either.
/ M59 Discussion Thread #434
Thanks for the thoughts Mike. You bring up some good points and I've thought about all that in the past.
Im actually considering a full size excavator and keeping my 4610 for a bit longer. I just have a "thing" for these M59's!
And yes, it's also a part of wanting another toy.
/ M59 Discussion Thread #435
I use the 3 point on my L39 a lot and it works fine - box blade, landscape rack, Harley rake, back blade, brush hog, disk harrow, 3-point splitter and 3-point chipper. I do have the tires loaded, but the L39 has small tires so it does not add that much weight. With a light weight box blade on the three point, I can move full, heaped, buckets of sand, but the back end is light and I need to run in four wheel drive. OK on flat ground but I would not want to do it on hills. The M59 has larger tires so you would get quite bit more weight by loading the tires, but it also has a much larger bucket so I expect you would need additional weight on the three point if you are going to do loader work without the hoe attached.
/ M59 Discussion Thread #436
I never took the backhoe off of my M59 but the guy I sold it to uses it without the hoe far more than with. He has a laser controlled box blade he pulls behind it on a daily basis leveling commercial construction sites. I see absolutely no disadvantage to it over any other tractor. The bucket is big and heavy but if it is a problem flip two levers and take it off.
/ M59 Discussion Thread #437
I took my backhoe off when I got it repaired. Of coarse my tires are not loaded but the thing seems pretty useless with no weight. Not sure loaded tires would make that much difference unless you were using a heavy implement out back. On gravel you would spin tires unless you were in 4wd.
/ M59 Discussion Thread #438
Does anyone make extended stabilizers for the M59 or 62? They're plenty strong but way too short to be effective.
Thanks!
Steve
/ M59 Discussion Thread #439
I posted in the Kubota forum, however I could find this M59 Thread so I'm posting again now that found this. I have a question in regards to my Front End Remote and the flow rate. I have looked at a brush cutter by Blue Diamond that has a mower that is has a low flow option if 16gpm, I think the M59 is 16.1. After reading the specs on the blue diamond site, they have designed a brush mower to take a lower flow rate without having the High flow system. What do you guys think of this attachment? I haven't spoken to the sales rep as if yet, hoping to get some advice and question I could bring to the rep if I should make a call to them.
/ M59 Discussion Thread #440
As far as another question to ask the manufacturer, I would find out what pressure they recommend if used with the 16gpm minimum flow, and compare that to what you have. I believe the M59 is somewhere around 2,950psi?
It looks like a nice unit and would sure be handy to have a mower mounted on the FEL. :thumbsup:
2017 Mack Semi (A64047)
2017 Mack Semi...
2022 EZ-GO ELITE...
2010 INTERNATIONAL PROSTAR PREMIUM ROAD TRACTOR (A63291)
2010 INTERNATIONAL...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
1062 (A63291)
1062 (A63291)
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
