M5700 Glow plugs?
/ M5700 Glow plugs? #1
GTinNH
Somersworth, NH
Kubota M5700/M4000
I feel a little dumb asking this question but I cant figure it out. I just bought a used M5700 from a private seller. currently it starts and runs great but looking ahead to the winter months I need to figure out how to use the glow plugs. I have a couple of older Kubotas but the glow plugs work on a seperate start/glow plug switch. The M5700 only has a key. How do I activate them? Thanks
/ M5700 Glow plugs? #2
Either they are one position before start on the key or you turn the key backwards.
/ M5700 Glow plugs? #3
Try rotating the key to the left and see if the light lights up. I vary the time I hold it on by how cold it is. Never more than 15 seconds and it starts right up. Thats the way my L4400 works
/ M5700 Glow plugs?
I have tried turning it to the left but it won't turn. Ill have to pay more attention to see if the light comes on 1 click before ignition.
/ M5700 Glow plugs? #5
When you turn the key to run, there should be a glow plug light on your panel light up... It is an automatic system and will Only light for a second (or less) depending on engine temp.
During winter it may light up for 5 to 10 seconds, again depends on engine temp...
/ M5700 Glow plugs?
I still am having trouble telling where the glow plug indicator is. I'm thinking the timer may be burnt out because I don't even see a light
/ M5700 Glow plugs?
If you look at the picture you can see the dash lights. I can see a fuel light and pto light and I think the one in the middle is an oil pressure light which is the only light that turns on when I'm starting it.
/ M5700 Glow plugs?
Ok I've figured it out! The glow plug position is between the "on" and "start" points on the switch. Seems like it works great
