Lynch Pins
/ Lynch Pins #1
man00
eastern ok
kubota
Mine aren't popping off/out, I keep breaking the ring that snaps in place to hold them..Now these are the cheap made ones, not even sure if they're Chinese quality.
/ Lynch Pins #3
I've broken a few of them, but I buy them 6 for a $1 at TSC. Can't expect much at that price.
/ Lynch Pins #4
The black ones have an extremely stiff ring, so I think it'd definitely solve the OP's issue.
I've never broken a cheap one though... and I think a lot of mine are from the HF assortment. There's not that much force on the "pin" part, and nearly zero force on the ring itself unless it's being contacted in an odd way. So maybe just changing your supplier would solve the issue.
/ Lynch Pins #5
2x on the black ones from TSC
/ Lynch Pins #6
/ Lynch Pins #8
I'll second or third the Black ones from TSC, but be careful they bit fingers, but they will do the trick! Lol
DevilDog
/ Lynch Pins #9
OK, you are sick of it by now but those black HD ones from TSC are tough.
I've never broken one of the blacks while several of the golden ones have either bent or the spring loop comes off. It doesn't happen often but it is a pain when it does.
/ Lynch Pins #10
On some of mine I have added a short length of very small chain that I wire (or bolt) to the 3 point arms.
Also I keep a selection in my mounted tool box along with various pins or suitable bolts to replace lost pins.
(had to drive back home with equipment dangling by a rope a couple of times)
Prevention is worth a pound of cure!
/ Lynch Pins #11
I found cure of that problem,couple more coins stop at tractor dealer buy the good ones...no more problems. :)
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
