LX3310 Exhaust Smell
   / LX3310 Exhaust Smell #11
The new engines definitely smell different. Whether it's worse or better depends on your senses I suppose. If you're around diesel equipment long enough you can become a real connoisseur.
   / LX3310 Exhaust Smell #12
There's a real big difference , old vs new My old dump truck puffs black smoke every gear ,the new one not one puff the exhaust pipe looks brand new .......
   / LX3310 Exhaust Smell #14
If there is enough antifreeze in the cylinders to cause that smell, it should be obvious looking at the reservoir level dropping over time. I'd also check the oil and look for that cream+coffee appearance. Together those would all be clues.
   / LX3310 Exhaust Smell #15
Welcome to the world of Tier 4 diesel engines. Obviously, you are sensitive to the smell of oxidized exhaust. I suggest getting rid of your new steed and buying a used Pre 4 emissions diesel. Only way to get around the non stink, stink.
Me, I'll never buy a T4 compliant diesel. The whole emissions thing with diesel engines is a joke in my view.
   / LX3310 Exhaust Smell #16
I have a sweet odor from my 1988 B2150 4 cyl Kubota. It does not show up until the machine is warm and been under load for a while. Really "pleasant" rather than irritating but also peculiar. Has gone on for MANY years and not related to antifreeze overflow or getting into cylinders. Yours has the smell immediately so obviously a different mechanism.
As for your 3310, I think your best solution is to reroute the exhaust pipe which is relatively inexpensive and a permanent solution. My larger Massey 2660 is a low profile and routes exhaust out under the rear, very similar to the old 1950's Fords and Fergusons.
   / LX3310 Exhaust Smell #17
88 is no emissions hardware at all. Just a road draft tube and you may be smelling hot lube oil. Mine do that, especially just after an oil change.
Hi, thanks, It's not coolant, the level has not changed and I've encountered that issue before. What's odd is that it happens immediately even on a cold engine. The exhaust pipe is not even warm. Start up after sitting 24 hours, immediate smell then as long as it runs. Hopefully it will get better over time. thanks
   / LX3310 Exhaust Smell #19
Agreed, but 7 hours?
Probably not.
It does not take much.
SDT
I see no evidence of a head gasket failure or coolant being burned. Hopefully it will get better over time.
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
PENDING SELLER CONFIRMATIONS (A58018)
PENDING SELLER...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A58018)
2013 KENWORTH T680...
2019 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2019 FREIGHTLINER...
2013 Ford F-550 Bucket Truck (A56858)
2013 Ford F-550...
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
