LX 2610 Cab - Gasket for 2WD-4WD Lever?
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #1
JME81
New England
Kubota LX2610HSDC
Hi,
I’ve looked through the parts catalog for the tractor but can’t find this part if it even exists. I think that there’s a gasket missing for the 2WD to 4WD lever, I noticed that it’s a pretty large opening to allow hornets through. Is there a gasket for this?
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #2
usually the smaller cabs are less sealed and more noisy it is why I went with the grand L40 series instead of the B series with cabs. that and I needed three rear remotes instead of just two.
That doesn't really help or answer my question.... I'm looking to see if there's a 1st or 3rd party option to seal that.
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #4
Sorry, let me re-phrase that. I don't think there is a factory option to seal up that lever other than upgrading to a grand L but if you like McGyver you can probably make something out of fabric and duct tape. I assumed you had looked through the catalogs online.
a rubber flap with a slot cut in it may work better since the throw of the lever is quite long and would be easier to make than a shifter boot style fabric and duct tape setup.
Good idea on the rubber- suggestions on where to look for that?
Here's the opening:
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #6
You're missing part number 100 on your diagram-yes?
The part number is given.
Good Luck!
Good Luck!
It appears that part # 100 is a boot but am not clear. I'm checking with Messick's as well. I was hoping that someone here has the same tractor to confirm that the boot is there.
Here's a place to start:
Or you could buy a door sweep and quickly fabricobble your own and have leftovers for your friends:
That's funny, I was thinking of the same thing...
Update, I found a Youtube video of my tractor model and there is a boot there. I'm pretty sure that part 100 is it. I'm going to go into my local dealer and see if they have it.
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #10
I stand corrected. Back when I was looking at a b3030 I was disappointed to see that the cabs are really not sealed very well. especially around the rear remote levers.
I guess at the price they charge now a days they had no choice but to improve the sealing.
2021 New Holland Workmaster 25S Compact Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 New Holland...
Danuser Digger F-8 (A52748)
Danuser Digger F-8...
Toro Workman Utility Cart (A51694)
Toro Workman...
CAT Skid Steer (A50322)
CAT Skid Steer...
2016 Genie GTH-636 Telehandler RIDE AND DRIVE) (A50774)
2016 Genie GTH-636...
Skid Steer (A51691)
Skid Steer (A51691)
