LX 2610 Cab - Gasket for 2WD-4WD Lever?
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #1
JME81
New England
Kubota LX2610HSDC
Hi,
I’ve looked through the parts catalog for the tractor but can’t find this part if it even exists. I think that there’s a gasket missing for the 2WD to 4WD lever, I noticed that it’s a pretty large opening to allow hornets through. Is there a gasket for this?
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #2
usually the smaller cabs are less sealed and more noisy it is why I went with the grand L40 series instead of the B series with cabs. that and I needed three rear remotes instead of just two.
That doesn't really help or answer my question.... I'm looking to see if there's a 1st or 3rd party option to seal that.
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #4
Sorry, let me re-phrase that. I don't think there is a factory option to seal up that lever other than upgrading to a grand L but if you like McGyver you can probably make something out of fabric and duct tape. I assumed you had looked through the catalogs online.
a rubber flap with a slot cut in it may work better since the throw of the lever is quite long and would be easier to make than a shifter boot style fabric and duct tape setup.
Good idea on the rubber- suggestions on where to look for that?
Here's the opening:
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #6
You're missing part number 100 on your diagram-yes?
The part number is given.
Good Luck!
Good Luck!
It appears that part # 100 is a boot but am not clear. I'm checking with Messick's as well. I was hoping that someone here has the same tractor to confirm that the boot is there.
Here's a place to start:
Or you could buy a door sweep and quickly fabricobble your own and have leftovers for your friends:
That's funny, I was thinking of the same thing...
Update, I found a Youtube video of my tractor model and there is a boot there. I'm pretty sure that part 100 is it. I'm going to go into my local dealer and see if they have it.
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #10
I stand corrected. Back when I was looking at a b3030 I was disappointed to see that the cabs are really not sealed very well. especially around the rear remote levers.
I guess at the price they charge now a days they had no choice but to improve the sealing.
2024 CATERPILLAR 255 SKID STEER (A51242)
2024 CATERPILLAR...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
1981 LINK BELT HSP 8028 (A50854)
1981 LINK BELT HSP...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
2005 INTERNATIONAL DURASTAR 4300 (INOPERABLE) (A50854)
2005 INTERNATIONAL...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
