LX 2610 Cab - Gasket for 2WD-4WD Lever?
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #1
JME81
New England
Kubota LX2610HSDC
Hi,
I’ve looked through the parts catalog for the tractor but can’t find this part if it even exists. I think that there’s a gasket missing for the 2WD to 4WD lever, I noticed that it’s a pretty large opening to allow hornets through. Is there a gasket for this?
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #2
usually the smaller cabs are less sealed and more noisy it is why I went with the grand L40 series instead of the B series with cabs. that and I needed three rear remotes instead of just two.
That doesn't really help or answer my question.... I'm looking to see if there's a 1st or 3rd party option to seal that.
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #4
Sorry, let me re-phrase that. I don't think there is a factory option to seal up that lever other than upgrading to a grand L but if you like McGyver you can probably make something out of fabric and duct tape. I assumed you had looked through the catalogs online.
a rubber flap with a slot cut in it may work better since the throw of the lever is quite long and would be easier to make than a shifter boot style fabric and duct tape setup.
Good idea on the rubber- suggestions on where to look for that?
Here's the opening:
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #6
You're missing part number 100 on your diagram-yes?
The part number is given.
Good Luck!
Good Luck!
It appears that part # 100 is a boot but am not clear. I'm checking with Messick's as well. I was hoping that someone here has the same tractor to confirm that the boot is there.
Here's a place to start:
Or you could buy a door sweep and quickly fabricobble your own and have leftovers for your friends:
That's funny, I was thinking of the same thing...
Update, I found a Youtube video of my tractor model and there is a boot there. I'm pretty sure that part 100 is it. I'm going to go into my local dealer and see if they have it.
   / LX 2610 Cab - Gasket for 2WD-4WD Lever? #10
I stand corrected. Back when I was looking at a b3030 I was disappointed to see that the cabs are really not sealed very well. especially around the rear remote levers.
I guess at the price they charge now a days they had no choice but to improve the sealing.
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2017 Case CX130D Excavator (RIDE AND DRIVE) (A50774)
2017 Case CX130D...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
Land Honor Quick Attach Accumulator Grapple (A50514)
Land Honor Quick...
