Lucas CAV pump part needed
/ Lucas CAV pump part needed #1
Flylow
Ford 2910
I am in dire need of a gov idle spring and pin for a Lucas CAV pump on a Ford 2910 tractor.
I bought a reseal kit and everything went great until I started to connect throttle spring to gov and realized I had lost the idle spring pin. If anyone knows where I can buy one new or used please let me know. I would greatly appreciate any help.
Thanks!
/ Lucas CAV pump part needed #2
Check around and see if you have a decent diesel repair shop. When I put new seals in my Case hoe, a local diesel shop had everything I needed, including a new spring. Different style pump, but parts did not come as a kit, rather in separate plastic envelopes, with the part number on it. I got all OEM CAV parts there, that were in the seal kit from Case, for a lot less money.
Use the CAV pump part number, hopefully they will be able to fix you up.
Its on the way.. just waitin on the mailman..
A huge thank you for helping me out. This forum is very fortunate to have you and others who have ton's of experience that are willing to unselfishly give there valuable time to help us not so experience folks.
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
