Lucas CAV pump part needed
/ Lucas CAV pump part needed #1
Flylow
Ford 2910
I am in dire need of a gov idle spring and pin for a Lucas CAV pump on a Ford 2910 tractor.
I bought a reseal kit and everything went great until I started to connect throttle spring to gov and realized I had lost the idle spring pin. If anyone knows where I can buy one new or used please let me know. I would greatly appreciate any help.
Thanks!
/ Lucas CAV pump part needed #2
Check around and see if you have a decent diesel repair shop. When I put new seals in my Case hoe, a local diesel shop had everything I needed, including a new spring. Different style pump, but parts did not come as a kit, rather in separate plastic envelopes, with the part number on it. I got all OEM CAV parts there, that were in the seal kit from Case, for a lot less money.
Use the CAV pump part number, hopefully they will be able to fix you up.
Its on the way.. just waitin on the mailman..
A huge thank you for helping me out. This forum is very fortunate to have you and others who have ton's of experience that are willing to unselfishly give there valuable time to help us not so experience folks.
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
213130 (A64276)
213130 (A64276)
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
2026 Electric Tricycle (A64194)
2026 Electric...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
