Lubrications
/ Lubrications #1
raw25
Fountain, MI
kobota rtv 1100
I have a 2015 John Deere 2025R . I’m having problems greasing the front end of the main drive shaft? I can see no way to do it. Any solutions ? Thanks
/ Lubrications #2
:welcome: to TBN
Prolly no zerk there at the spiders on each end of that front drive shaft.
/ Lubrications
:welcome: to TBN
It sure looks like there is and they show the location in the manual . But the angle is the problem. Thanks for replying
/ Lubrications #4
Use a mini needle grease gun with a rigid tube (not a flexible hose), and a squeeze grip lever. Much easier to press the needle on the zerk than to try and get a fitting over the zerk in the u-joint
/ Lubrications #5
That's how I do my 2320. Gets easier with practice.
/ Lubrications
Thanks for replying. We will try that.
/ Lubrications #7
I cannot even see my front Ujoint on the 2016 2025R. Cannot get grease into even the rear one because they put in a 45 degree zerk. Think I'll eventually try unscrewing it and putting a plain, straight one to get that one greased.
The front Ujoint on the 4010 (like a 2019E) at 660 hours and 9 years completely disentegrated. Traded for a very lemony 1025R and then back to a 2 series 2025R less than 2 years later.
Think I'm likely just going to trade for a Kubota in 3 or 4 years' time.
Ralph
/ Lubrications
I wonder how hard it would be to remove the driveshaft lube it and put it back on?
/ Lubrications #9
I think that you will find that a needle fitting will be easier
/ Lubrications #10
I have a tough fitting on my Tundra front driveshaft and lubed it with a small angled swivel fitting. I had to use the smallest one as the other two, while not much bigger, didn't work.
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2015 Nissan Frontier 4x4 Crew Cab Pickup Truck (A61573)
2015 Nissan...
