Lubrications
/ Lubrications #1
raw25
Fountain, MI
kobota rtv 1100
I have a 2015 John Deere 2025R . I’m having problems greasing the front end of the main drive shaft? I can see no way to do it. Any solutions ? Thanks
/ Lubrications #2
:welcome: to TBN
Prolly no zerk there at the spiders on each end of that front drive shaft.
/ Lubrications
:welcome: to TBN
It sure looks like there is and they show the location in the manual . But the angle is the problem. Thanks for replying
/ Lubrications #4
Use a mini needle grease gun with a rigid tube (not a flexible hose), and a squeeze grip lever. Much easier to press the needle on the zerk than to try and get a fitting over the zerk in the u-joint
/ Lubrications #5
That's how I do my 2320. Gets easier with practice.
/ Lubrications
Thanks for replying. We will try that.
/ Lubrications #7
I cannot even see my front Ujoint on the 2016 2025R. Cannot get grease into even the rear one because they put in a 45 degree zerk. Think I'll eventually try unscrewing it and putting a plain, straight one to get that one greased.
The front Ujoint on the 4010 (like a 2019E) at 660 hours and 9 years completely disentegrated. Traded for a very lemony 1025R and then back to a 2 series 2025R less than 2 years later.
Think I'm likely just going to trade for a Kubota in 3 or 4 years' time.
Ralph
/ Lubrications
I wonder how hard it would be to remove the driveshaft lube it and put it back on?
/ Lubrications #9
I think that you will find that a needle fitting will be easier
/ Lubrications #10
I have a tough fitting on my Tundra front driveshaft and lubed it with a small angled swivel fitting. I had to use the smallest one as the other two, while not much bigger, didn't work.
72'' Skid Steer Bucket (A61567)
72'' Skid Steer...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
Sterling 9500 (A61307)
8'X28" Table with sink and dishwasher inlet (A60352)
8'X28" Table with...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
