Lubricating the Pedal Shaft
/ Lubricating the Pedal Shaft #1
Mosey
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I can't find grease zerk #20, which they call the "Pedal Shaft". I took off the left cover under the dash and looked in there, but didn't see anything. Is it under the tractor? I thought maybe they meant the Clutch Pedal shaft, but that's #9 in the chart, or the Brake Pedal shaft, but that's #18 in the chart, or the HST Pedal Pivot, but that's #23 in the chart. So, I'm stumped on this one. I have attached the diagram.
/ Lubricating the Pedal Shaft #2
If I'm remembering correctly my TC18 had two zerks for the brakes. Follow the rod from the brake pedal under the tractor towards the left side. Good luck.
hazmat - Thanks, I found it. There's also 2 zerks on the clutch pedal rod, one under the pedal and one towards the inside of the tractor (to the right).
2012 International 4300 Reefer Truck (A61306)
2012 International...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A59228)
2025 Kivel Quick...
iDrive TDS-2010H...
Blue Diamond 103709 (A53317)
Blue Diamond...
2017 BX2680 Sub Compact Utility Tractor (A61306)
2017 BX2680 Sub...
Tank Only (A59076)
Tank Only (A59076)
