LT1042 PTO dead
/ LT1042 PTO dead #1
bankershrs
Roscoe, IL
Cub Cadet LT1042
I pulled deck to clean, when putting back together I was not sure where the belt guard that goes over PTO aligned with PTO. There are 2 slots in the PTO, thought one side of the guard was to be in one of the slots on the PTO. Might have put in wrong slot on first try. Blew fuse when PTO engaged. Took bracket off, put on other slot on PTO, PTO still not working but not blowing fuses. Any ideas? Is there a good diagram available that shows where the bracket should be positioned around the PTO? Could I have toasted the PTO (electric)?
/ LT1042 PTO dead #2
Did the PTO assembly rotate around on you when you cranked the engine over? You might have torn the wiring harness out of it, or yanked it hard enough to break insulation, now it's shorting out.
The connector pigtale is sealed into the unit, but I have read where a talented feller or two were able to take the PTO apart and rewire it successfully. A bit beyond my scope!
Joel
/ LT1042 PTO dead
Yup, after I posted, I found that the wires had separated. Tried splicing together, still nothing so guessing they are also pulled out inside the unit itself. Thanks for reply.
/ LT1042 PTO dead #4
Try to Google "broken PTO wiring" or the likes. There may even be a YouTube video of someone opening one up to repair. The other option is replace the whole PTO with new, but they're a nightmare to remove from the crankshaft and they're crazy expensive.
Joel
Case IH 5100 (A64119)
Kubota L3901HST
Kubota L3901HST
PALLET OF DISCHARGE HOSES MISC SIZES (A68842)
PALLET OF...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
