LT 16 starting problem
   / LT 16 starting problem #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I thought I had a dead battery. I tried to jump it with battery hooked up and without only get a clicking sound ???
   / LT 16 starting problem #2
Check your safety switches. PTO,brake,seat etc.
   / LT 16 starting problem #4
On my trim mower the seat switch trans neutral and PTO have indicator lights that will tell you they are working. I can't tell you how many times someone has my "....." won't start and the trannie is not in neutral PTO not off parking brake not set etc.
thanks for the reply. Dropped it off at the shop yesterday. Should know something by the 22nd of the month.
   / LT 16 starting problem #6
It's not a safety switch. You won't get anything with a switch open.
The 'click' is likely the starter solenoid, so I'd guess that the starter itself is dead. It could be as simple as a loose wire.
JayC
Edit: Oops - I see that you went the shop route - so, what was the verdict?
   / LT 16 starting problem #7
Actually with one of my switches PTO I think, I get a definite click when turning to start.
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
2014 Ag Spray Schaben Sidedresser (A55301)
2014 Ag Spray...
2017 Polaris 500 Ranger Diesel Utility Cart (A53421)
2017 Polaris 500...
JOHN DEERE 2150 TRACTOR (A51406)
JOHN DEERE 2150...
