LT 16 starting problem
   / LT 16 starting problem #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I thought I had a dead battery. I tried to jump it with battery hooked up and without only get a clicking sound ???
   / LT 16 starting problem #2
Check your safety switches. PTO,brake,seat etc.
   / LT 16 starting problem #4
On my trim mower the seat switch trans neutral and PTO have indicator lights that will tell you they are working. I can't tell you how many times someone has my "....." won't start and the trannie is not in neutral PTO not off parking brake not set etc.
thanks for the reply. Dropped it off at the shop yesterday. Should know something by the 22nd of the month.
   / LT 16 starting problem #6
It's not a safety switch. You won't get anything with a switch open.
The 'click' is likely the starter solenoid, so I'd guess that the starter itself is dead. It could be as simple as a loose wire.
JayC
Edit: Oops - I see that you went the shop route - so, what was the verdict?
   / LT 16 starting problem #7
Actually with one of my switches PTO I think, I get a definite click when turning to start.
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A54313)
2010 FREIGHTLINER...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
2024 VOLVO VNL760 SLEEPER TRUCK (A54607)
2024 VOLVO VNL760...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
