Ls xr3135 diagnostic port?
   / Ls xr3135 diagnostic port? #21
I wonder if its different on the 3000 series of tractors
   / Ls xr3135 diagnostic port? #23
I am asking because I have access to a new holland dealer scan tool. Ls and new holland use different plugs and when I asked the ls dealer that told me there is a different plug thay thay use and not the obd2. Thay said obd2 was just thare because it was mandatory.
New Holland and LS do use different plugs as you noted but they both do the same thing. OBD2 and a Deutsch round for LS and New Holland respectively. The round is what is used across the CNH product line so using the round keeps it simple The LS dealership is feeding you a line IMO.
Now the question comes in as to which New Holland software that you have. If you are talking about the the electronic service tech software, I don't believe that will work. Pretty sure the NH techs use LS interface and software on the Boomer and Workmaster series but I'm trying to go from memory.
I know when I run the software and pick the boomer series there is a place for models equipped with ls engines.
   / Ls xr3135 diagnostic port? #25
You still haven't said what software?
Your thread is like giving us a yard of sand one grain at a time.
Case/new holland electric service tool.
   / Ls xr3135 diagnostic port? #27
What exactly are you trying to do with the software? Obviously your looking to do more than read and reset codes.
   / Ls xr3135 diagnostic port? #28
I get the impression he's want to tweak/tune/adjust some kind of setting for engine performance or emissions and is hoping he doesn't end up with a giant yard ornament.
   / Ls xr3135 diagnostic port? #29
That would be putting a great deal of trust in pirated software.
Software is not pirated. Have family that's works at a new holland dealer in the service department. He's not machanicly inclined so he has no idea how to use it. But he can bring it home on weekends. I'm an auto tech so I understand obd2 but the adapter it has is a 9 pin and ls has obd2 but now that I know it is just can bus but with a different connector I'm just going to make up an adapter.
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55315)
GMC 3500 Extended...
2020 FREIGHTLINER CASCADIA SLEEPER (A57880)
2020 FREIGHTLINER...
Eaton Air Compressor (A56857)
Eaton Air...
CANOE (A56859)
CANOE (A56859)
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
