LS XR 4145 HC first 50 hours
   / LS XR 4145 HC first 50 hours #21
I was just thinking that if its on the bottom it leaves some room since I only had 1/8" steel available to use. this way it can bend up some without hitting anything. also, to remove or install just set in on jack and apply a bit of pressure to plate and frame so it stays in place while installing the bolts. then when its time to remove for service put jack under, remoe bolts and lover jack. My next project now is to fasten the tow hooks to the frame just behind where the brush guard mounts. I see there are holes on each side. Where are you guys hooking the rear of the tractor to your chains while towing? I hooked to the loader 2"x2" tube steel at the rear yesterday.
Duff, this question is off topic, but one of your pictures is of interest to me. I have a pole barn for tractor/implement storage that has a dirt floor. I intend to put gravel in it. One of your pics shows a similar situation. Has that setup worked satisfactorily for you? What type stone did you use, crusher run or a clean/washed type? Any information or suggestions would be welcomed.
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
John Deere 1025R (A53317)
John Deere 1025R...
