Loader LS XG 3135H Tractor Attachments
   / LS XG 3135H Tractor Attachments #1
DonHite
Missouri Ozarks
LS XG 3135H
I just bought a LS XG 3135H Tractor. I have been a case unloader man until I discovered a LS dealer near my home. After visiting the lot several times I took their bait, and now I am the proud owner of a new tractor.
My question is what kind of attachments go on the front. Will any quick release type attachments work?
When implements say they are skid steer is that the same as a quick release?
I apologize in advance for my ignorance but this is the first tractor I ever owned.
   / LS XG 3135H Tractor Attachments #2
Yes they should fit UNIVERSAL SKID STEER MOUNT you can put forks, different buckets.....
   / LS XG 3135H Tractor Attachments #3
What kind of attachments go on the front? Will any quick release type attachments work?
"SSQA" is the abbreviation for Skid Steer Quick Attach. Any attachment labeled SSQA will fit the SSQA front mounting plate on either a tractor or skid steer.
The three most common SSQA attachments are an FEL bucket, FEL pallet forks and FEL grapple.
IMPLEMENTS, relative to tractors, refer to Three Point Hitch tools which are pulled.
implement
noun [ C ]
UK /ˈɪm.plɪ.mənt/ US /ˈɪm.plə.mənt/
a tool that works by being moved by hand or by being pulled across a surface:
garden/household/agricultural implements
Shopkeepers are not supposed to sell knives and other sharp implements to children.
CAMBRIDGE DICTIONARY.
ATTACHMENTS refers to tractor FEL tools.
Thank you both it is beginning to make since to me now. I will look and see what kind of forks and front hay spear I need to get.
   / LS XG 3135H Tractor Attachments #5
Get lite forks if you get heavy duty ones 5k they weigh to much and you lose lifting capacity..... titan makes a combo forks and spears ....:)
So for my tractor the forks need to be Universal skid steer mount and lite correct?
   / LS XG 3135H Tractor Attachments #7
Thank you so much guys. Now I can spend some more money! I looked at the Titan ones at my local MFA store abut I like the look of the Tomahawk forks better. Thanks Peter 315.
   / LS XG 3135H Tractor Attachments #10
Other recommendations might be made if we knew what tasks you want to use the tractor for. There are guys here with lots of experience and some that are just really good at spending other people's money :D
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2022 Ram 2500 4x4 Crew Cab Pickup Truck (A55973)
2022 Ram 2500 4x4...
TANK MANIFOLD (A58214)
flatbed trailer 24ft (A56858)
flatbed trailer...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
