LS vs. Kubota questions
   / LS vs. Kubota questions #41
I'm not quite following you. Try comparing LA853 to LA854 where the SSQA when from being optional to standard. The biggest change should not be in the lift capacity, but in the roll back.
how much does the SSQA components weigh?
   / LS vs. Kubota questions #42
If its measured at the pins does it matter which bucket or attachment method?? Just curious?
   / LS vs. Kubota questions #43
   / LS vs. Kubota questions #44
No....... :)
Exactly... The lower rating of the new loaders is either taking into account the heavier added tier 4 components, or is subtracting the added weight of the standard SSQA components. "At the pin" still means at the pin.
   / LS vs. Kubota questions #45
That makes sense, adds the physical weight, not calculating mechanical disadvantage.
   / LS vs. Kubota questions #46
If this has been asked, I apologize. But are these loader specs founded when attached to a tractor, if so what tractor size? Or are they published based on engineering data using pin placement and mathematics?
   / LS vs. Kubota questions #47
According to TractorData the bare, no-FEL L60's are only about 100lbs heavier than the L40's they replaced - unlikely to make enough difference to be revising the FEL specs. One would indeed expect the SSQA to make the bucket, etc., a little heavier (100lbs?). But still, that additional 6" SSQA gap has to make a noticeable difference in both curl and lift capacity, particularly with the smaller Kubota models the OP was comparing.
   / LS vs. Kubota questions #48
doesn't change the "At pivot pin" measurements. I can have a quick attach plate that sticks out 100" (exaggeration) ... But it doesn't change the pivot pin measurement. Now, I agree that the "At bucket edge" measurement will be different IF a SSQA plate is added, and the same depth bucket is used for the measurement. But, the 'Bota specs specify "At pivot pin" for the numbers I'm referring to... So, it makes sense that the weight of the SSQA components is what is decreasing the loader lift on the L60 vs L40 series machines.
Well, I pulled the trigger today. My new LS XR3135H is being delivered on Thursday!!!
   / LS vs. Kubota questions #50
Congrats! The LS really seem like a good value with lots of features. If I had an LS dealer local, they would have been my choice too.
   / LS vs. Kubota questions #51
And we love pics, please post some up when you get it!
   / LS vs. Kubota questions #52
Seems to be a lot of trigger pulling lately. Picking up a new PTR :Dmyself this weekend.
image-2450663750.jpg image-3625276322.jpg image-3100278551.jpg image-3056299622.jpg image-3917715961.jpg
Sold the Kubota 4 hours after the LS was delivered.
   / LS vs. Kubota questions #57
Congrats on the new tractor. She's a Beaut!!!!!
Anxious to hear your opinions about the differences. Looks like you've got a smaller chassis tractor? Should create some interesting comparisons.
   / LS vs. Kubota questions #58
   / LS vs. Kubota questions #59
I have a L3200, same frame & loader as the L3901, just less HP & emissions.
I can fill a 250 gallon IBC tote over 1/3 less than half full of water before the loader stops lifting it. 1/2 full = 1,000lbs. Add a couple hundred lbs for forks & 50-100 for the tote plus the fact that IBC tote sticks out 3' & the rated capacity is about right.
I've helped a neighbor move some big rectangular bales. No clue how heavy, but they felt about as heavy as my IBC tote I think. Those bales maxed out my tractor & moving them was a little sketchy. I kept them low & went really slow. I'll help him in the future with his remaining bales, but neither of us wants to deal with large bales again. He got rid of the goats & is selling the remaining hay, but would have gone to small bales.
At any rate, while a L3xx0 or L3xx1 tractor will barely do it, it is not an appropriate tractor if you are planning on moving big bales. It's just not that safe or enough tractor. A 4000 series would be the minimum I'd recommend, probably even a 5000 series.
As others noted the L 00 & 01s are economy models. The Grands (40 & 60) tractors have more weight & capacity than equivalent economy models, not to mention other bells & whistles.
Weight defines how much a tractor can do. HP just defines how fast it can do it. Compare weight of a machine before you compare HP
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
2019 BOBCAT E45 EXCAVATOR (A59823)
2019 BOBCAT E45...
