LS Tractor Floppy Bucket Syndrome?
   / LS Tractor Floppy Bucket Syndrome? #51
Watching to see if he found anything. I have never had over heating problems. Mow a good bit with it dry. I don't have cab or air. Don't wash it out that often and have not over heating problems. I would like to know the outcome with all of his problems. I know he was also working on his A/C. He was going to sale tractor when he got everything fixed.
If you keep the radiator and the grills on the hood blown out .. no over heating issues. If you have a cab .. you blow out the evaporator core when you clean the radiator. Simple!
Fact: maintenance .. doesn't do itself!
Well look at this. A lot happens then you take two weeks off and go on vacation. I was at my land in the mountains of CO doing all kinds of great stuff with my skid steer. Sorry, I don't have good internet there yet.
Where do I start?
Well, right before I left on vacation LS reached out to me and talked to me about my tractor. This was nice. +1 to LS for calling me. Then my dealer started responding to me again shortly after. This was nice "mostly". I was asked by LS what would make me give LS another try and hopefully give me a better experience with the brand. Since asking for a refund would make me happier to be done with it but would still leave a bitter aftertaste, I told them if they did what I had been asking for since 2017 (swap out my tractor for a new one that works) I would do my best at giving it a go again and try to focus on the new tractor and not the issues with the old (sorry for the run on sentence). Since it seemed to be going well, in good faith I also made my videos that maybe shed some negative light on the LS brand to "private" in YouTube, as a token of goodwill. Did I have to do this? No way. This should have been fixed years ago and not been an issue we are even taking about. But again, in good faith I did it to see where this will go.
That has been 2 weeks now, and I am waiting on a formal response. If they don't swap it out for a working tractor, I will just reset the videos to "public" again and be on my way trying to fix this tractor to probably sell. If they do swap it out for a new one, which should have been done when they could not fix it, then I will leave them private and see how the new one goes. If it does well then great for LS and I can make all the happy videos like some here do about how I love my tractor (or try my best because some of those videos are just boring). You will know when I know.
As for the floppy bucket issue, yes I have cycled the cylinders over and over and over and over for 4.5 years. That does not matter. After a few times using the bucket it goes back to floppy. If you don't care, then fine; don't! If you want to use the bucket for grading or cutting then you probably will, but whatever. Some of you just don't get it and that is fine. I have a skid steer now that does work correctly and I don't use the tractor for that anymore. I still want it fixed. I have friends I refereed to LS and they have it. I would like to show them a fix and open their world to proper loader function. If I get a new one, I want that to work right also. I want a real fix; that's it. Why is that so hard?
Did the dealer tell me about this. Yes and no. Not before I bought it. I did not check that because I had never seen that issue before. I had a new compact John Deere tractor and it did not do it. My older Kubota subcompact did not do it. As user PCABE5 said, his New Holland that is the exact same model as my LS does not do it. When I asked the dealer about it all I was told was its "normal" and they told me about the "fix". It works for like one or two dumps then its back to floppy. I don't want to keep cycling the loader every few times I use it just to make it work as it should. If they do swap me out with a new one, I will test it and see if it does it. I am hoping they have made improvements that got rid of the issue. I know they changed a lot of parts since 2015.
So YES, I have tried the "fix" and it does not "fix" it. Its a one or two cycle fix and then its back to not working right. That is not a fix. That is a work-around to temperately hide the symptoms. I run my tractor at 2000+ RPMs pretty much always. Mine still does it. I have tried it at 2500+ rpms and it will still do it. Its less floppy, but its still not how it should be.
I want to know why this is common with LS (and the other "off" brands it seems) but not with the New Holland with the same base tractor, JD, Kubota, Mahindra, ... I hear a lot of "sort of" fixes and theories, but no real fixes. I hear about "fast dump", but I do not think these loaders have that. I did not see it in the manual (but I could have missed it). People can keep throwing out guesses, that is fine. That is how the internet works. But I want a real fix.
And no CADplans, I will not complain about getting dirt out of my bucket. I know how to do that just fine. I have a full sized backhoe, a track loader, a bulldozer, an old new holland tractor and a skid steer that do not have "fast dump" and I can clear the buckets and blade with no issue.
Man, I know you like the dealer but you seem to not even read or hear what I have said about the overheating. I understand only hearing what you want to, but I have spelled it out many times.
The radiator, evaporator, hydro and oil coolers are all clean. I unbolt the sides to get in between them and wash them out. The hood is clean. I even bought the tools you say you told them about to wash out the coolers. It still overheats. Its been doing it for 3.5 years. It still does it. Maybe if LS does swap it out for a new one you can go there and do all your wonders on it to fix it. Maybe you can fix what they have not. Or better, buy it from them since I apparently have no clue on how to clean out coolers.
Customer Service has mostly went the way of the DoDo Bird though. Very discouraging, when you spend that kind of money on a tractor and the company won't even step up and communicate.
Thank you Doofy. Some people understand. I am not poor, but I don't like throwing away $30,000 and then be all happy about it.
   / LS Tractor Floppy Bucket Syndrome? #55
I wish you luck. With your insulting attitude .. you'll certainly need it.
   / LS Tractor Floppy Bucket Syndrome? #56
I am glad that LS has finally began a dialogue with you and I hope the result is positive. :drink:
   / LS Tractor Floppy Bucket Syndrome? #57
Good. That's what I was hoping for.
I hope you got a specific contact name and direct callback number though.
How is my attitude insulting and yours not? I understand you have no skin in the game and can say whatever, but you keep downplaying my issues like I don't know how to use a tractor.
I get it, you like your dealer. That's great, but that does not change the issue. Good salesmen will always make you feel like a friend until you really need them for something.
"Where Everybody's Family." I know my family would have never let me deal with this much headache. So no, I am not family. I am a customer that got a bad run and was left with $30,000 in the trash.
Telling the truth can sound insulting, but its really just hard to hear by people that don't want to hear it.
Thank you. I did and I was told they are still working on the issue.
   / LS Tractor Floppy Bucket Syndrome? #60
Good to see you back brs. Hopefully you enjoyed your 2 week vacation.
I am also glad to hear that LS is (hopefully) working with you to resolve your issues. :drink:
12' CONTAINER (A52706)
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2006 APPA TL (A55787)
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
DEUTZ MARATHON...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
