LS tractor bucket flop
/ LS tractor bucket flop #1
George2615
Super Member
Central Square, NY
LS XR3037HC
/ LS tractor bucket flop #2
No worky
No, float mode works fine. That is dump mode. Loader valve does not have fast dump (or regen). Once you dump the bucket there was no (or low) pressure in the line. At that point if you float the loader down and start backing up to back drag, when the bucket touched the ground it would not stay at the set angle. As the video shows I can manually lift the bucket after completing a dump. I've since installed a flow restrictor in line which has virtually eliminated that problem.
/ LS tractor bucket flop #5
Why didnt you post this in the hydraulics thread?
Politics would be bettter then here.
