LS TRACOR WITH BACKHOE
/ LS TRACOR WITH BACKHOE #1
ALVINM
LS R MODEL
I am a new owner of an LS tractor and bought a backhoe attachment. After hooking up all of the hydralic lines the backhoe will not work unless someone sits on the tractor and holds the remote control lever.. Is there a way to engage this that I dont know about?
/ LS TRACOR WITH BACKHOE #2
Yes, just bungee the remote lever to on, ;and then operate the BH.
You could also bypass the remote, by running a hose from FEL PB out directly to the rear with QD, and hose from the BH PB port to the IN port of the remote. The tank hose needs to go to tank. So now, at the rear, you have two hoses with QD's, and one hose for tank. You would plug in the BH hoses, tank hose to tank and be fine.
If you have the BH removed, then connect a short jumper to the two QD;s .
The removed BH should have three hoses attached. Wrap the hose ends when storing.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
