LS MT3 57 Regens TO Often
   / LS MT3 57 Regens TO Often #21
The more hours I put on my tractor (this is my first tractor with a DPF), the more I realize that it's complex. On one hand, if you understand passive vs active regen, it would make sense to run it hot (over 2,000 rpms all the time) to keep the dpf hot. On the other hand, the higher the rpm's you run, the more soot you produce.. common sense. I have done the thought experiment at length, and my theory is this... after running a tractor for 20+ years, you become very familiar with the conditions that make your tractor produce black smoke (soot). Essentially, a rich air/fuel condition. Biggest example... running at low rpm's while also putting the tractor under a heavy load (lugging). Also, what I call 'jockeying' the throttle... in other words, changing throttle settings too often.. because as we all know, every time you throttle UP, there are a few seconds where the mixture is rich and you dump soot out of the exhaust. So, I have been running my tractor at whatever RPM's I choose. I let it idle for several minutes while I am bucking logs for the sawmill, or stacking lumber, etc. But when the tractor is moving, I keep the rpm's up high.. and try not to adjust the throttle very much. Everything works better that way. After 400 hours on the this tractor, I think I about have it figured out (hopefully!).
   / LS MT3 57 Regens TO Often #22
I have an mt357 as well. I usually run it at pto speed flail mowing.
I have 180 hours and have regenned at 50, 100 and 150 on the nose every time.
The one thing my dealer told me was to run it at high rpm: “these machines are made to work”
More fuel? Sure. Any complaints, nope. Since it has a 10 gallon tank, I only buy fuel when I need it so it’s fresh and always use a fuel stabilizer.
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
