LP Gas tank problem
/ LP Gas tank problem #1
randy41
Linden VA
the valve on the tank thats hooked up to my grill is very stiff. Is there a way to fix that? Would squirting some WD40 down the shaft be ok to do? the tank is kinda full. should i wait until its empty to try to fix it?
/ LP Gas tank problem #2
Wait until it's empty and bring it to on of those tank exchange places. They take almost anything, even the old style tanks as they replace everything anyway. Just for liability purposes. That's why they're so expensive.
/ LP Gas tank problem #3
I would not use WD-40 unless it's wet! But a little BreaK-Free CLP down the valve stem wouldn't hurt anything at all, and it may help.
How old is the tank? I'm assuming it's one you own rather than an exchange unit.
/ LP Gas tank problem #5
i can't see what harm spraying wd-40 on the thing will do: give it a shot.
heehaw
/ LP Gas tank problem #6
The valve may have a packing gland that is too tight but if you are not familiar with how these work they are best left alone.:D :D
Especially with a full tank!:D :D
2020 CATERPILLAR 239D3 SKID STEER (A65053)
2020 CATERPILLAR...
2022 Case 5550 Trident Spreader LOW HOUR (A63689)
2022 Case 5550...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2004 Chevy 2500 Pickup Truck (A66408)
2004 Chevy 2500...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2022 Ram 3500 Hauler Truck, VIN # 3C7WRTCLXNG270348 (A65563)
2022 Ram 3500...
