Tiller lowest tiller setting
/ lowest tiller setting #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Hi,
which holes on the 3pt arms will let my tiller dig the deepest?
can tell and tired of playing with it, thanks, brett
/ lowest tiller setting #2
Tiller depth is usually set by adjusting the skid shoes on the tiller itself.
/ lowest tiller setting #3
The only way that would make any difference is that if you have telescoping rock shafts. Making them longer would technically make them lower/closer to the ground when the rock shafts where down... But only very slightly. Actually I've never had telescoping links - they are mainly just for ease of connection - not to run in the extended mode... right ?
I always set my depth on the tiller its self. It has adjustable skids.
tom
/ lowest tiller setting #4
<font color="blue"> which holes on the 3pt arms will let my tiller dig the deepest? </font>
On the lift arm....The ones closest to the tractor and on some also the higher up holes.
On the lift rod....The hole closest to the bottom.
vince,
sorry, I dont understand what you mean by skid shoes. Seems to me that my tiller is only limited in depth by how low the tractor arms will allow it to go, brett
/ lowest tiller setting #6
Your tiller must be differant than the ones I'm accustomed to..
2012 Ford F350 Truck (A62679)
2012 Ford F350...
40ft Shipping Container (A65583)
40ft Shipping...
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
