Tiller lowest tiller setting
/ lowest tiller setting #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Hi,
which holes on the 3pt arms will let my tiller dig the deepest?
can tell and tired of playing with it, thanks, brett
/ lowest tiller setting #2
Tiller depth is usually set by adjusting the skid shoes on the tiller itself.
/ lowest tiller setting #3
The only way that would make any difference is that if you have telescoping rock shafts. Making them longer would technically make them lower/closer to the ground when the rock shafts where down... But only very slightly. Actually I've never had telescoping links - they are mainly just for ease of connection - not to run in the extended mode... right ?
I always set my depth on the tiller its self. It has adjustable skids.
tom
/ lowest tiller setting #4
<font color="blue"> which holes on the 3pt arms will let my tiller dig the deepest? </font>
On the lift arm....The ones closest to the tractor and on some also the higher up holes.
On the lift rod....The hole closest to the bottom.
vince,
sorry, I dont understand what you mean by skid shoes. Seems to me that my tiller is only limited in depth by how low the tractor arms will allow it to go, brett
/ lowest tiller setting #6
Your tiller must be differant than the ones I'm accustomed to..
New 43X16-20 NHS tire on 6-lug John Deere compact tractor rim, Coal Valley, IL (A65640)
New 43X16-20 NHS...
White 5100 4R Planter (A66408)
White 5100 4R...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A64553)
2016 Kubota SSV75...
