lower link cat 1 pins
   / lower link cat 1 pins #1
spo307
Levittown & Long Eddy NY
kubota L4400
do these look like the correct lower link pins? width form hole to nut?
Lower Link Pin, Category 1 Adjustable, 7/8 in. dia. - 0268420 | Tractor Supply Company
   / lower link cat 1 pins #2
There is many different styles...the ones you listed are "adjustable" because they have that thin nut on the inside, there is also the type that has a flange there instead.
The ones you listed will work great...use loctite on the threads.
   / lower link cat 1 pins #4
I would not use weld on pins-if you can find them, I have never seen them. Do you have a TSC nearby? They have the different styles in stock usually.
no i was om there website, ur saying it is threaded but has a metal stop instead of a nut
   / lower link cat 1 pins #6
Hello
Put this number in the search box at TSC and I think this is what you want.
07020800U
$2.99
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
(3) Stihl Chainsaws (A50123)
(3) Stihl...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Pallet of Asphalt Hand Tools, Shovels, Rakes, Bru. (A52384)
Pallet of Asphalt...
