Low tech compact tractor options
/ Low tech compact tractor options #1
Bloemie
South Eastern Ontario, Canada
Kioti NX4510 HST
I am looking for a low tech tractor. Something with as little electronics, plastics and gadgets as possible. I guess I could buy vintage, but iin the +- 35 HP range, what is the caste iron options, and not the teflon coated light weight versions to look at? Call it zen farming, but, I am not looking for cup holders
/ Low tech compact tractor options #4
Look at Branson/Korean in compact tractors.
Branson is big in Texas and California, reasonably popular along the Gulf coast. Not many Branson dealers away from the coasts.
Look at Mahindra and John Deere in heavier models.
In Mahindra, not the compact tractors, which are made for Mahindra by LS of Korea, but the heavier models, made-by-Mahindra-in-India models.
John Deere also has a couple made-in-India economy 'E' models which are heavy and basic.
LINK: TractorData.com John Deere 5075E tractor information
Not for me, likely good for you.
/ Low tech compact tractor options #5
Massey Ferguson made some up till the late 90’s / early 2000’s
231S for example
John Deere also has a couple made-in-India economy models which are heavy and basic.
Interesting, The pricing for Mahindra here in Canada seems to favour the heavier versions. Something I did not realize till you mentioned it and I looked them up- thanks!
I dont farm cash crops and I dont expect to ride it for hours but pull it our when I need the muscle. I could probably get away with a compact, but likely find the occasional tine I wish I had more....
/ Low tech compact tractor options #7
If you add your LOCATION to your T-B-N PROFILE, so your location shows with every post your author, you will receive responses germane to your operating conditions.
1. Click on your "illuminated" screen name in upper right corner.
2. Click on SETTINGS in drop down box.
3. On left side of screen, click on ACCOUNT DETAILS.
4. Scroll down to LOCATION.
/ Low tech compact tractor options #8
I dont farm cash crops and I dont expect to ride it for hours but pull it out when I need the muscle.
Tractor capability is more closely correlated to tractor weight than any other single (1) specification.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
/ Low tech compact tractor options #9
Here's the tractor we put together to meet your specs. 33 hp & 4 speeds. Wish it were shorter & smaller, athough I can't fault the reliability. Something to consider is that even though it has power everything, it's still a handful.
You want cast iron options? Shucks, even the throttle lever on this one is cast iron. In fact, the dash board where the throttle lever, gauges & switches mount is also cast iron. That dash al by itself itself must weigh 40 llbs. Wheels are also cast iron as are their internal hub gears which adjust the wheel width.
It always starts and runs the same. It's never needed much repair or even attention.
rScotty
/ Low tech compact tractor options #10
Mid 90's, used. Lots of choices. Get one with hydro drive, and a loader.
/ Low tech compact tractor options #11
I would look at Kioti LK3054xs or the updated LK30. The 3054xs is a simple, mechanically injected, mechanical shut down, no fuel solenoid 3 cylinder engine with advertised 30.5 hp, 4 wheel drive with an eight speed gear .transmission [4high-4 low two speed reverse] drop dead simple tractor. The xs version was first produced in 2004. The LK30 is the same mechanically but with an updated 3 cylinder engine [not sure about the solenoid shut down feature on this model]
/ Low tech compact tractor options #12
Kioti LK30​
Kioti LK30 Power
Engine (gross):30 hp
22.4 kW
PTO (claimed):23 hp
17.2 kW
Dimensions
Wheelbase:64.6 inches
164 cm
Length:111.4 inches
282 cm
Width:51.4 inches
130 cm
Height (ROPS):88.6 inches
225 cm
Weight:2,897 lbs
1314 kg
Ground clearance:10.8 inches
27 cm
Front tread:43.5 inches
110 cm
Rear tread:40.2 to 49.9 inches
102 to 126 cm
Transmission
Type:synchronized shuttle
Gears:8 forward and reverse
/ Low tech compact tractor options #13
Just saw a new video today from Mike at LSE in Nashville. He carries Branson now, too.
/ Low tech compact tractor options #15
I was also in the market for a low tech sub compact. I ended buying a 1980s Ford 1200 FWD 10 speed manual trans with a FEL and rear blade. I haul logs and slash with the FEL and maintain my mountain driveway. It's only 16HP diesel but does everything I need. The PTO driven flail mower in being delivered tomorrow :)
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
GATOR UTV (A63276)
GATOR UTV (A63276)
2024 JCB 35Z (A60462)
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
