Low hour diesel engine failure.
/ Low hour diesel engine failure.
Yes, it was rebuild. Head was machined, and the valves ground. They said it made factory spec. Compression after they rebuilt it.
/ Low hour diesel engine failure. #122
Yeah, I really wish I knew the whole story. What really bothers me is that their not giving me any reasons (Other "Gas was run through it" statement.) why this happend. So how am I supposed to keep this from happening again, if I don't know what caused it?
I wounder if I could contact Deere directly..
I worked at a Deere factory as a pipefitter and the assembly lines were shut down a couple times for fuel contamination. I thing the problem was a little diesel in jet fuel, if I remember right, but what happened was when the fuel company filled the fuel tanks there was some residual fuel in their hose from a previous fill. These fuel trucks held 3 or 4 different fuels and there wasn't any way to clean the hoses totally before the next fill. Maybe?
On that note, I don't know how much gas in diesel is acceptable. I have already started pumping gas in my diesel truck, a couple gallons, and ran with it and it works fine.
/ Low hour diesel engine failure. #124
YesDeere said:
That's pretty dirty. But I have to agree. Buyer beware eh?
That's why I only buy new. I don't trust anyone when it comes to the expensive stuff. Personally I don't even trust dealers to work on my stuff. Especially when it took a Chevy dealer 4 hours to swap out wheels under warranty.
/ Low hour diesel engine failure. #125
Just when you think you're safe, you trust someone else to rotate your tires and they bust your hubcabs, only to be discovered later when the chance for a dispute is gone. My dealer begged me for months to let them change my oil so I did. Guess what, the oil pan nut was not tight. Good thing I caught it.
/ Low hour diesel engine failure. #126
clemsonfor said:
What about the pistons and the rings and sleeves?
New rings, and these small motors don't have sleeves. The cylinders looked pretty good, but they cleaned them up some. New bearings too.
The guy that did the rebuild, was their new top mechanic that they just hired. Supposedly has lots of experience.
/ Low hour diesel engine failure. #128
ORCM I think you should be good to go with that rebuild.
Some enjoy tilting with windmills too much. :)
Life goes on and at worse it is just a tractor engine and not a spouse's heart that may stop beating.
A few good things came of this. One is my wife appreciates having a tractor more. Seeing that nothing gets done without it, opened her eyes.
Now maybe I can work on getting an upgrade.
/ Low hour diesel engine failure. #130
Now that's the most optimistic post in this whole thread :)
/ Low hour diesel engine failure. #131
I still wonder what they did to screw up the motor. ORCM, yeah you started the problem, but they sure did a good job of making it worse by a hundred times. If I were you, I'd be glad the dealer realized they screwed it up and fixed it, they could have left you with the big bill.
/ Low hour diesel engine failure. #132
Yea, over all I think that Deere dealer is one of the good ones based on this thread.
It took them a while to find the thorn in their shoe, but when they found it, they took care of it, and you.
A lot of car and probably tractor dealers would have been finding a way to weasil out of some or all of the responsibility here
/ Low hour diesel engine failure. #133
You hit the nail right dead square on the head!!!
:hammer:
I would like to know this too. I've never seen rings stuck like that before. I'm wondering if they squirted a bunch of starting fluid in it. I also think not having water in it and trying to get it to run, didn't help. Don't forget they were missing with the pump timing too. It says right in the service manual, that messing with the injection timing can damage the motor.
/ Low hour diesel engine failure. #135
Glad things worked out for you. I have to agree with some of the others on selling the tractor and getting something else. My gut feeling is that it will never completely be the same and issues could arise down the road.
Also, this thread illustrates the reason I will NEVER take anything to a dealership for any kind of work. I have never met a dealership mechanic that I thought was truly competent. Almost everything we've taken in in the past has ended up either with other issues or unneeded work done. I even stand by this for warranty work. I do it myself and just suck it up on the price for parts, knowing it will be done right if I do it.
With that said, (and I don't want to sound like I'm blaming him) I bet if the OP had just let the tractor sit in his shop for a few days while he thought about the problem (or asked advice on here) the whole dealer issue could have been avoided, problem fixed, and he'd still have a like new tractor.
I do agree that the dealer made good on it by not charging anything, I'd definitely buy another tractor from them, but I'd never set foot in the service dept again.
/ Low hour diesel engine failure. #136
The only right way to sell this tractor, is to disclose all of this to the new buyer.
Seems odd that everyone thinks the dealer ought to stand by their sale, but that private party is buyer beware.
It would be more honorable for all TBNers to hold themselves to the same standard they expect from the dealers.
U want the world to be a better place?
It begins with u and me.
/ Low hour diesel engine failure. #137
So very true.
I suppose the correct thing to do is trade it in at the same dealer, now they can stand behind they're own work.
/ Low hour diesel engine failure. #138
yelbike said:
So very true.
Excellent option.
/ Low hour diesel engine failure. #139
That's very easy to say when it's not your money
But I agree it would be the right thing to do. In a perfect world
/ Low hour diesel engine failure. #140
ORCM you know there was some management changes in the shop. You know the business manager/owner/JD are stand up people.
You also expect if you sock a bunch of hard hours on it over the next month and it blows or other wise messes up they will be open to looking into what went wrong.
What you will never know for sure is what mistakes by you and the shop caused what and you need to try to move past the past.
Per what you stated the rebuild included new bearings, ect too so it was no HACK job and those doing the work where told to MAKE IT RIGHT most likely.
You can trade or do what every you like but I think some of the fear mongers are just that. I would think twice about trading off a 2007 tractor with a 2012 new like engine if the trade was going to cost me over $5K.
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
