low height dump trailer
/ low height dump trailer #1
Stimmy60
Southern In.
L4630
Does anyone know of a manufacturer who makes a dump trailer that sets low and has short sides in the 6' x 12' size?
/ low height dump trailer #2
I would contact a company you like and ask them to custom build to your size. Most of the times its not a big deal. I just bought a low profile dump trailer from PJ Trailers but it is bigger then what you wanted. You can get them in 12' length but the width is going to be an issue as its 83" wide.
PJ Trailers - 83" Low Pro Dump (DL)
/ low height dump trailer #4
RollTideRam said:
If you get it to low, the trailer will hit the ground when you dump.
Not if their designed properly.
/ low height dump trailer #5
You might consider two-axle model MUTS Trailer from Canada.
Youtube: MUTS Trailer.
info@muts.ca
I have abused a single axle MUTS (Multi-Use-Trailer-System), 1000 pound payload, for a year in Florida and it has held up well. MUTS dumps with a rope winch and column; simple and durable. I pull the MUTS behind a Kubota RTV500 Utility Vehicle and the trailer is as much of a "go anywhere" tool as the Kubota itself.
JBS352
/ low height dump trailer #6
/ low height dump trailer #7
CAM Superline or Maxim both make a low profile tandem axle dump in a 6x10 and 6.5x12 i believe.
/ low height dump trailer #8
the cam my neighbor purchased had issue's when dumping.Maybe the changed the way their built now this was 2 years ago. I.d ask the question before purchase for sure
/ low height dump trailer #10
Check out CornPro. They make excellent quality trailers.
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
CATERPILLAR 305E2 EXCAVATOR (A65053)
CATERPILLAR 305E2...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
