Low GPM 3pt log splitter
/ Low GPM 3pt log splitter #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
I asked a local log splitter manufacturer about using a 3" cylinder instead of a 4" one so I could get a bit better turnaround time. He said he has done this before. By switching to a 3" cylinder and making the total split length 20" he said it would be acceptable although not fast on my 4110 (5.5 GPM implement flow).
I don't do things in a hurry and to be honest I think I might be happy with the 4". Cycle times are slow, but who cycles the head all the way through the log most of the time anyway.
So I was wondering what the TBN wisdom on this would be. It would reduce the force to 12Tons, but again, I don't see that I need 20 tons. In the thread about electric log splitters people seem happy with 7 tons or even 4.5.
I don't heat with wood and only split maybe a cord a year, but rental around here is $65 for 4 hours and that includes time to get it and return it and I'm tired of that. I want to split when I want to split. This splitter would be $500 if I go pick it up. It's their 20Ton model, just with a smaller diameter cylinder.
Thoughts on this strategy?
Cliff
/ Low GPM 3pt log splitter #2
Cliff:
If you'll be happy with it, that's what counts. If you are going to be running it by yourself, you don't need the fastest cycle time anyway. I'm just an impatient old SOB. /forums/images/graemlins/grin.gif
From point of view of performance, If you are going to be splitting mostly smaller rounds (6-12") it should be fine. But were it me, I think I'd stick with the 4" cylinder and accept a slower cycle time. Presumably, you're going to be doing this on weekends, when it's nice to be outside and you're in no particular rush anyway.
I think that it is larger rounds, or splitting with a 4-way or 6-way wedge that is apt to require more power. Timberwolf makes a quality splitter with a 4" cylinder.
</font><font color="blue" class="small">( . . . I think I'd stick with the 4" cylinder and accept a slower cycle time. Presumably, you're going to be doing this on weekends, when it's nice to be outside and you're in no particular rush anyway. )</font>
Well, exactly. On the other hand, I don't want to get bored waiting either.
Cliff
/ Low GPM 3pt log splitter #4
If that works for you, fine. Usually a 20 ton splitter is woefully inadiquite in the Minnesota hardwoods I deal with, so I'd rather have a slower 4" or 5" cylinder.
--->Paul
/ Low GPM 3pt log splitter #5
For the amount you are splitting, the slow cycle time shouldn't be a problem.
Unless there is some physical reason, I can't see shelling out big bucks for a splitter. That amount can be done by hand easily.
Of course thee is always the "toy" factor of which I have way too many sitting around.
Harry K
/ Low GPM 3pt log splitter #6
If you do get impatient with the 4" cyl.. you can always rig up a pto pump, an extra spool set, and resv' and then split wood blindingly fast..
For what it's worth.. I run a fel on a tractor that has a 4gpm pump.. works good enough for me. I know people running loaders on tractors with 2.9gpm pumps, as well as splitters on those same tractors... Just however long you want to wait is the issue.
Soundguy
/ Low GPM 3pt log splitter #7
I run a 3pt splitter on my old IH 300U. It is not fast but as others have noted when working by yourself you can't go all that fast anyway. Mostly I am splitting old locust and am able to crack them pretty well (sometimes the stump end of the tree is tough). I would say if you are splitting for yourself and working alone it will be fast enough to suit you.
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2015 KOMATSU PC360LC-11 EXCAVATOR (A64279)
2015 KOMATSU...
UNUSED ATSPOWER 40 GALLON AIR COMPRESSOR (A64281)
UNUSED ATSPOWER 40...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
Caterpillar D6 Dozer Service and Parts Manuals (A63117)
Caterpillar D6...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
