Low Cost Brush Forks
   / Low Cost Brush Forks #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
Check out my cheap brush forks! :D I got the idea from LostInTheWoods. They work pretty good.
   / Low Cost Brush Forks #2
Now you've gone off the edge...
   / Low Cost Brush Forks #3
Excellent. Now attach a cross-brace 2x4 to the inside ends of those 2x4's, inside the bucket, to connect the "teeth" together & help them resist moving side-to-side (rotating around your clamp).
Oh, and cut the ends of the "teeth" so they're points! :thumbsup:
I was thinking of bracing it somehow...I must say...For light use, they work pretty good....:thumbsup:
   / Low Cost Brush Forks #6
I think Jake98 is just jealous he didn't think of doing that. :laughing: ;)
If you moved them out to the ends of the bucket so they are against the sides then put a cross brace at the rear they would be pretty well locked into position. You could also add a third fork in the middle for smaller branches.
Yeah, probably. ;) I'll have to try putting in a brace. I have a couple more 2x4's...
   / Low Cost Brush Forks #8
attachment.php
   / Low Cost Brush Forks #10
That's the idea but I'd move the two outside ones out each way till they are against the sides of the bucket like I said in my previous post. By doing that and adding the back brace like you put in your sketch, you will really lock the forks into position.
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
1267 (A50490)
1267 (A50490)
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
