Lovejoy couplers
/ Lovejoy couplers #1
Oaktree
Super Member
Coös, N.H.
Kioti LK3054xs
Not really sure where to post this, hope it's semi-appropriate here.
Had to replace the engine on my 25 year old log splitter last week. I noticed that the plastic "spider" in the lovejoy coupler was gone. Put it back together without it, but the owner's manual has dire warnings about running it without that piece. Will I really trash the hydraulic pump without it? Who knows how many years ago it deteriorated and fell out (I bought it used about 10 yr ago).
Where would I get one of these things? I know Amazon has them, but I hate to put in an order just for a $3 part...the shipping alone would be twice that.
/ Lovejoy couplers #2
I have Amazon prime so I'd just ordered it. The local electric motor repair shop has them. I don't know if it would hurt the pump or not. Is it worth $3 to find out for sure?
/ Lovejoy couplers #5
Don't run it without it. It went on my splitter and the hammering between the lovejoy connectors quickly sheared them off. I was wearing hearing protection and thought it sounded a little noisy but was almost done. I found that Fastenal has them and the were much cheaper than buying MTD parts.
/ Lovejoy couplers #6
most industrial supply stores will also have them such as motion, Purvis, Applied industrial etc.
/ Lovejoy couplers #7
Ditto what has already been said. INdustrial supply or tractor supply store. They are really popular in industry. Commonly stocked and frequently used at most all industrial mfg places.
Just get the series number off of it. IE: L095, L099, L100, L110, etc. That will tell you what spider you need. And I'd probably buy 2 and have a backup.
Not sure what size you have, but none are expensive. Heres one for Under $5 to your door New Lovejoy Martin Type L090 L095 Rubber Spider Insert Buna N | eBay
I am guessing that a local brick and mortar store is gonna be more than that.
/ Lovejoy couplers #8
TSC carries LO95 couplers and spider. They call them L Jaw buna spider if you look them up online-$6.99
/ Lovejoy couplers
OK, I'll stop by my friendly local Fastenal and pick up a couple.
/ Lovejoy couplers #10
I would guess fastenal, Grainger, MSc, etc is gonna be about $10 ea. If you don't need them in a hurry, you are really better getting them online.
/ Lovejoy couplers #11
Definitely replace it. Running without it is like driving around with a missing suspension bushing: a harsh ride and an expensive repair bill in no time.
/ Lovejoy couplers #12
In your area give Eastern Industrial a call they should have it 800-244-1500 you will need the size most likely a L90/95 or L99/100
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2011 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2011 Caterpillar...
2019 Ford F-450 Liftmoore 1032 3,200lb. Crane Service Truck (A64556)
2019 Ford F-450...
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A63276)
2014 MACK ELITE...
