Love My BX23
   / Love My BX23 #1
BigD23
Platinum Member
Pac. NW
Kubota BX23 TLB
Hello all...This is my first posting...Used my new (to me) '05 BX23 backhoe yesterday to dig a 60' trench 3' deep to run a new electrical line...My Kubota worked so well it almost made me look like I knew what I was doing...Have removed 5 stumps since I purchased it two weeks ago and I'm very happy so far with what it'll do...Sold my old orange friend (B5100) and upgraded to this...If there's anything I'm not too thrilled about it's the electrical part of it...When I looked at/bought the tractor I tried the lights of course and everything worked fine...Trailered it home and when I drove it off the trailer I noticed the lights were on...Checking the light switch (which was off) I thought uh oh...Going to have to troubleshoot that part and see where the short is and clear it...Looking forward to reading more about the BX23 and others on this forum.
Don
   / Love My BX23 #2
Probably moisture in the switches. Happens to a lot of them. I drilled a small hole in the bottom of mine, blew them out and put some wd40 in them and haven't had a problem since.
Welcom to TBN
   / Love My BX23
Hi Bernie, thanks for the input...Wiggled wires around and pulled the plug connector to the back of the switches and the lights/blinkers still stay on...Going to have to "dig deeper"...
Don
   / Love My BX23 #4
I had moisture and dirt in the actual switch bodies. They actually come apart somewhat. I removed them from the tractor and sprayed wd40 and used an air hose to blow out and haven't had the problem again.
   / Love My BX23
Hi Eric, I've got the plug connector completely off the switch body and the lights are still on...Must be shorting out somewhere up the line...Thanks for the help.
Don
   / Love My BX23
Front and rear lights are on...Flashers were till I removed the plug from underneath the dash.
Don
   / Love My BX23 #8
Don
Thats really strange, keep us informed.
The hot wire to the lights has to be shorting with another hot wire.
The headlights normally go off with the key. Do yours?
   / Love My BX23
The lights do go out when the key is turned off...Thought I was done yesterday and had the BX put in the barn when my daughter comes in the house to tell me she sees water bubbling up and around one of my in ground freeze proof water faucets.....Ratttttttssssssss....Fired up the Kubota and went to work digging around it to find a tree root had decided the plastic 1" line going to it needed to let nature push it around and cracked it....Bought/installed a new in ground faucet and pipe later on in the day.
Don
   / Love My BX23 #10
If he is really pulling the switch connector and they are still on, this is nearly impossible to accidentally happen. There is no relay, just the switch.
(otherwise I would bet $$ it's a wet switch)
RDnT
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2025 New/Unused Wolverine Ripper (A51573)
2025 New/Unused...
LMC LOT NUMBER 269 (A53084)
LMC LOT NUMBER 269...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
