Lotus Welders
/ Lotus Welders #1
hr3
Mid. Coast Maine
7610 hst
I'm looking at a Lotus # LTAW2000D and one of the local stores but can't find any information on line about.. What should I look out for or any thoughts.?? Remember I am now living in the Philippines have an old military jeep that needs some love.. Thanks
/ Lotus Welders #2
Lotus # LTAW2000D?? Never heard of that model #
I have the Lotos LTPDC2000d
3 in 1 200 amp tig,stick, 50 amp pilot arc plasma cutter
It has worked well- other than needing to clean the contacts in the plasma cutter torch handle,
going on 3 years of use so far. for what it cost it has been a good deal.
If you buy 1 I would suggest working it hard right of the bat- that's what I did if it makes it through the free return period you will probably be OK
/ Lotus Welders #3
Any sort of "FREE RETURN PERIOD" from the Philippines, might be somewhat problematic.
/ Lotus Welders
Not a problem with the return, Everything at the 2 stores is guaranteed for a full year. They test everything that goes out the door..even light bulbs..
/ Lotus Welders #5
True- OP may want to find out EXACTLY what the (local) Philippines store's warranty return/replacement policy is first.
The lotos are very inexpensive units - for the power output and duty cycle specs. but if you get a bad unit, then it can be a headache.
If buying new Miller, Lincoln, Hypertherm for the same jobs he can probably buy a better condition Jeep instead- maybe even 2
/ Lotus Welders
Can't find Miller or Lincoln here or I would but them. I have to drive 5 hours just to get inch sized wrenches.. lol We already know how they stand by there customers here , our China made generator had a leaky petcock and they fixed it free,, and our gas stove blew it's igniter and that was replaced free.. So i'm not too worried about replacing a 135 dollar welder..
As for the Jeep lol 1943 Willys walk a few feet in my shoes.. Everything here is steel and concrete not much woodworking so the welder will get many other projects done as well..
/ Lotus Welders #7
I assume the Lotos you are talking about is a 120V unit.
Wouldn't a 240V unit be better in the Philippines?
/ Lotus Welders
Well I ended up with a ZWELD mma-160 xi only 160 amp but for what I am doing it will be fine.. Inverter type 20amp 240 volt.. We will see tomorrow how it works.. too hot out right now.. :)
/ Lotus Welders #9
Amazon shows that model requires 30amps
2007 TEREX ADVANCE MIXER FD3000 AWD 6X6 FRONT DISCHARGE MIXER (A59910)
2007 TEREX ADVANCE...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59910)
2025 TEXAS PRIDE...
WABBLE BOX & HYD PUMP (A63745)
WABBLE BOX & HYD...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
Volvo EC210CL Excavator (A64047)
Volvo EC210CL...
