Lotus Welders
/ Lotus Welders #1
hr3
Mid. Coast Maine
7610 hst
I'm looking at a Lotus # LTAW2000D and one of the local stores but can't find any information on line about.. What should I look out for or any thoughts.?? Remember I am now living in the Philippines have an old military jeep that needs some love.. Thanks
/ Lotus Welders #2
Lotus # LTAW2000D?? Never heard of that model #
I have the Lotos LTPDC2000d
3 in 1 200 amp tig,stick, 50 amp pilot arc plasma cutter
It has worked well- other than needing to clean the contacts in the plasma cutter torch handle,
going on 3 years of use so far. for what it cost it has been a good deal.
If you buy 1 I would suggest working it hard right of the bat- that's what I did if it makes it through the free return period you will probably be OK
/ Lotus Welders #3
Any sort of "FREE RETURN PERIOD" from the Philippines, might be somewhat problematic.
/ Lotus Welders
Not a problem with the return, Everything at the 2 stores is guaranteed for a full year. They test everything that goes out the door..even light bulbs..
/ Lotus Welders #5
True- OP may want to find out EXACTLY what the (local) Philippines store's warranty return/replacement policy is first.
The lotos are very inexpensive units - for the power output and duty cycle specs. but if you get a bad unit, then it can be a headache.
If buying new Miller, Lincoln, Hypertherm for the same jobs he can probably buy a better condition Jeep instead- maybe even 2
/ Lotus Welders
Can't find Miller or Lincoln here or I would but them. I have to drive 5 hours just to get inch sized wrenches.. lol We already know how they stand by there customers here , our China made generator had a leaky petcock and they fixed it free,, and our gas stove blew it's igniter and that was replaced free.. So i'm not too worried about replacing a 135 dollar welder..
As for the Jeep lol 1943 Willys walk a few feet in my shoes.. Everything here is steel and concrete not much woodworking so the welder will get many other projects done as well..
/ Lotus Welders #7
I assume the Lotos you are talking about is a 120V unit.
Wouldn't a 240V unit be better in the Philippines?
/ Lotus Welders
Well I ended up with a ZWELD mma-160 xi only 160 amp but for what I am doing it will be fine.. Inverter type 20amp 240 volt.. We will see tomorrow how it works.. too hot out right now.. :)
/ Lotus Welders #9
Amazon shows that model requires 30amps
2014 Ford E-250 Cargo Van (A61573)
2014 Ford E-250...
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
REDDICK 1000 GALLON POLY NURSE TANK (A63291)
REDDICK 1000...
2016 Hyundai Sonata Sedan (A61574)
2016 Hyundai...
Challenger 65-85C Tractor Service Manual (A63117)
Challenger 65-85C...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
