lost tractor key
/ lost tractor key #52
When I brought my tractor back to town I forgot to take the key out of the ign. When I got home it was gone, probably the big keyfob blowing around pulled it out.
So I made a key by memory out of Aluminum and used it for a month. Then one day lifted the seat and there was my original key - it didn't get far! But I couldn't throw away my new "spare" handmade key, kept using it. Then someone else started the tractor & broke it off in the hole. GRRRRRRR....that was a hassle taking the lock apart. Got spanked for that one !
Another time, a friend called and wanted to use my tractor. I had the key 100 miles away. So I texted him a photo of the key and a couple dimensions. He made one and started my tractor.
This is a Kubota B2710. Very simple key.
/ lost tractor key #53
The TC40DA and the Boomer 8N use different keys. I bought my TC40DA used with only one key. I just received the 2 spares I ordered from Messick's. Easier than driving 86 miles round trip to the closest dealer.
/ lost tractor key #54
Removing the key sends a message to a friend or neighbor who tends to borrow your tractor without permission. They're not trying to steal it, just borrow.:laughing:
/ lost tractor key #55
For a Model, it's the same exact key... and that same key may be used on several different models. I think only kubota sells them, I don't think a locksmith has "blanks".
Yes, correct. No keymaker has the blanks. They are unique to Kubota. And the lousy dealer I went to charged me $12 and some odd cents for 2 keys. What a ripoff. May have cost them 25 cents. By the way, I have two B2150s, a BX2200 and have bought a BX2230 and another BX2200 for others. All those keys are the same.
And Massey Ferguson keys are the same across a broad bunch of models. One dealer told me not to bother to leave my key with the tractor there because they have one that fits all of them. Entirely possible there is a different key for each major model line or something but that was not the impression I got from the dealer.
/ lost tractor key #56
How did u misplace the key while driving the tractor? Can u remove the key and it will keep running? Never tried. I had an ole amc hornet that u could do that with. :)
Yes, one of my B2150's will not retain the key. You can pull it right out while it is running. I have to keep a lanyard on the key looped around the throttle lever to keep from losing the key. I assume the switches wear in that manner.
/ lost tractor key #57
Our B3030 cab tractor takes a "B" key while the door locks use a "L" key.
So I can start a B or L tractor with my keys.
Can anyone verify other Kubota key types so we can start collecting them?
Sure would be handy when visiting the dealer lot!
/ lost tractor key #58
Not true, they key blank for my Grand L series Kubota is used on Satoh Mahindra and some Kobelco. Has ILCO 1540 as the blank number.
Ilco 154 Kubota Tractor Key Blank Pack of 1 - - Amazon.com
The key situation depends on which vendor is used for the key switch, Kubota may have a few tumbler profiles exclusive to them but the switches are used all over the place.
David
/ lost tractor key #59
David
No typical, handy and readily available key maker in your hometown -- like Lowes or Home Depot or your hardware store -- carry blanks for Kubota keys. TRUE.
Among other things, the Ilco blank you show on Amazon does not fit any of my Kubota tractors. P1030496.JPG
/ lost tractor key #60
<snip> Can u remove the key and it will keep running? Never tried. I had an ole amc hornet that u could do that with. :)
On my M4700 the key is a rather simple key. I was able to go to my local "key shop" (Baldino's) and they had a blank made by Ilco and I had them make several copies for about a buck each (I tend to misplace keys). This tractor requires pulling out a lever to stop it. Key turns it on, but not off.
My B7610 it has one of the "universal Kubota small tractor keys" which I think I paid about $2@ at my local Kubota dealers. They remind me of the keys I use to get in small german hotels, big and clumsy so we rarely carried them around just left them at the desk.
GMC 2500HD 4wd Service Truck (A61307)
GMC 2500HD 4wd...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
Zero Turn Mower (A59231)
Zero Turn Mower...
MMS 750 Remote Control Lawn Mower (A60463)
MMS 750 Remote...
2023 CATERPILLAR 279D3 SKID STEER (A62129)
2023 CATERPILLAR...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
