Lost steering control on YM330D
/ Lost steering control on YM330D #1
jerhutch
Ym330D
I lost control of my steering. It was working ok until one day it suddenly I got several inches of play, then I could spin the steering wheel with no movement in the pitman arm.
I suppose I will have to remove and replace the upper shaft but it looks like a significant and expensive project. Any thoughts as to what else it could be?
Thanks
Jerry
/ Lost steering control on YM330D #2
could be a sheer pin on one of the shafts. check to see if the shaft running through the pitman arm is moving. is there any vertical play in the sterring wheel. Only a teardown will settle the question of what is wrong.
Normmm,
No sheer pins, based on the parts manual. The shaft connecting to the pitman arm is not turning.
Thanks
Jerry
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
Dodge 4500 Bucket Truck (A63689)
Dodge 4500 Bucket...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
