Lost Dump Pressure
/ Lost Dump Pressure #1
RealJimbo
I was moving dirt, the other day. While dumping my loads, I was pertially driving up the dump pile. On one occasion, the edge of the bucket came down on to the pile annd I started rolling backward. Mistakenly, I attempted to dump the bucket further, and since this would have had to pull the tractor up the hill, this didn't work.
I now have up and down pressure on the loader, up pressure on the bucket curl, but NO DUMP PRESSURE ON THE BUCKET. When I dump it goes slow. If I attempt to hold the edge of the bucket against the ground, it just gives way.
This is a Woods 126 FEL on a Kubota M6040. Bugs me too, because though they always say not to scrape backwards with the bucket edge, I had done so many times with my prior M5040 with a Kubota loader. Not sure what the difference is between the Kubota loader and the Woods, but so far I wish I had the Kubota loader back.
Any assistance in getting back my dumpt function would be greatly appreciated.
Jimbo
/ Lost Dump Pressure #2
If you have QD in the circuit, unplug and re-plug.
/ Lost Dump Pressure #3
could it be a blown O ring in your bucket cylinder? Or are there two cylinders on the loader?
The Woods126 has two cylinders.
Ok, I hate doing this, but . . . what is QD?:ashamed:
Ok, so I appreciate the assistence above.
That said, I go out and diconect all the QD's from the FEL. I reattach. Still operates the same. It seems that the right side IS pushing down, but the left is not. I decide to actually go take a look at the bucket and cylinders.
****!:thumbdown:
Another lesson learned. When something stops functioning as it did/should, take the time to check things over.
The rod broke the weld on the bucket end. Though it is tempting to re-weld it, the rod does not seem to be actuating and is leaking. I'm assuming the rod bent before the weld broke.
I got a price of ~$170 for the cylinder assembly. Plus shipping. Picture 042.jpg
/ Lost Dump Pressure #6
I would also guess you bent the rod. To check for a bent rod place the bucket flat on the ground and then try to dump the bucket. Pressure will build and the left cylinder should extend.
Roy
While I'm exposing my ignorance . . . when the new cylinder arrives, in what position should the other cylinder be in to assure that the two ar 'in sync'?
I never have liked this Woods loader vs the Kubota loader . . . especially all the exposed hydraulic hoses. The Kubota's was all metal tubing. Much neater and no ill-effects from UV rays.
/ Lost Dump Pressure #9
You could try and fill the cyl first, or just connect the hoses and operate the levers.
It may take about 5 complete cycles to purge the air from the cyl.
The FEL valve will supply fluid to the cyl with the least resistance first.
BOBCAT CT4058 TRACTOR (A64280)
BOBCAT CT4058...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
1999 Bell B25C 6x6 25 Ton Articulated Dump Truck (A61572)
1999 Bell B25C 6x6...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2009 Chevrolet Tahoe SUV (A61574)
2009 Chevrolet...
(APPROX. 9) ROLLS OF WRAP (A63291)
(APPROX. 9) ROLLS...
