Loss of power
   / Loss of power #31
You might also want to pick up a tube of water sensing paste. $10 for a tube that will last you a lifetime. smear a bit of the yellow paste on a dip stick and put to the bottom of your tank. Stuff turns bright red in the presence of water. (It's used in gas stations on the end of stick they use to "stick" the tank. Since the water will always be at the lowest point you just need a little bit on the end of whatever you're sticking the tank with.
Where do you purchase this?
   / Loss of power #32
Kolor Kut was the stuff I bought. Do a google on water sensing paste and you'll get a bunch of hits, then just find a place that will sell single tubes. All gas stations use the stuff.
   / Loss of power
Installed the filter - 5 minute job. Tractor actually feels to have more power. I ran BH for about 30 minutes and it just purred along at 1800 rpm @ 32 fahrenheit temps... Put the box blade on and went down the road to do a little work... no issues...
I would install one just as preventative maintenance...
Lloyd
   / Loss of power #34
I had a problem of losing power after working for a while. It was found by mistake while the dealer was looking for the problem and loosened a fuel line to check the flow. He was hosing fuel off the injector pump and the revs increased. It was a bad pump that lost pressure when hot. Easy to check.
Kubota LX2620 (A53317)
22' x 23' All Metal Garage (New/Unused) (A59225)
22' x 23' All...
2007 CHEVROLET KODIAK C4500 (A58214)
2007 CHEVROLET...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
2018 Bandit 15XP Wood Chipper (A57453)
2018 Bandit 15XP...
