Dirt Moving Losing power and smoking
/ Losing power and smoking #1
docone
Wainwright Alberta
Kubota MX5100HST, B6200D
I have a 2012 MX5100 HST (900 + hours) and while using it to move sand( trenching a frost wall) it started losing power and smoking from the exhaust pipe. It still runs smoothly until I start to load it up. I usually run between 2000 and 2200 RPM when using the loader. I'm thinking maybe injector plugging up or valve train adjustment.
Anybody out there have experience with this type of issue?
Any guidance would be appreciated.
/ Losing power and smoking #4
What color "smoke"?
White? Blue? Black?
Purple? šŸ˜‚
/ Losing power and smoking #5
I overfilled the crankcase with oil once - it idled fine but under a load it smoked and lost power.
/ Losing power and smoking #6
As others stated change fuel filters & check for good fuel flow from tank to inj pump. Check to be sure fuel tank is venting by operating with fuel cap removed & shop towel covering the fuel tank neck.
Thanks for the replies, the smoke is bluish.in color indicating oil burn, possibly plugged crankcase vent.
After doing an oil and filter change, fuel filter and both inner and outer air filters, i started it up and ran it at idle for a few minutes. I then increased RPM slowly to 2200 and all seemed good. then maxed out the throttle at 2800 RPM, it started to falter and belched out some black smoke for a bit then seemed to settle out.
Maybe wet stacked??
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2018 Nissan Rogue SUV (A59231)
2018 Nissan Rogue...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
