Losing Pins
   / Losing Pins #1
Charlie175
Virginia
Mahindra 2015 gear
Anyone else have trouble keeping the retaining pins on? I do custom BushHogging and loader work with my 2015 and it seems every time I end up losing some pin or another from the 3 point ball mounts, sway chains, or this weekend it was from the drawbar retaining pin and I almost lost the drawbar. I guess the vegetation just reaches up and grabs them.
   / Losing Pins #2
You might try replacing them with bolt and lock nut. Kind of a pain if you switch implements a lot but for a mostly dedicated bush hog or drawbar it should work.
   / Losing Pins #3
I purchase the black pins from Tractor Supply and they are stronger springs. the cheap gold color I have wondered it they don't pop out on there own .
Give them a try.
ken
   / Losing Pins #4
i ENDED UP USING CINCH STRAPS ON PIN CLIPS.
   / Losing Pins
Thanks guys! I will look over these options.
I kept buying the gold snaps since that is what the local hardware store carried.
   / Losing Pins #7
If you want to go through the trouble get some wire leader (fishing line) and a crimping tool and make lanyards for your pins. Another choice is sash weight chain easy to bend, wire, zip tie, solder or weld to pins. Back when I was writing specifications for trucks any pin that could be remove was attached with some kind of lanyard.
   / Losing Pins #8
I took the cheap approach & use paracord to "leash" mine...
Nick
   / Losing Pins #9
The 99 cent black lynch pins at Tractor Supply have about three times the spring-circle tension of the zinc chromate/gold lynch pins.
This will be your simplest solution.
   / Losing Pins #10
The gold ones I got from Agri Supply have very strong spring tension. They are actually a little hard to open and if you’re not careful they will pinch the sh*t out of you.
2015 Freightliner M2 106 26ft Box Truck (A50323)
2015 Freightliner...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2019 Chevrolet 2500 4x4 Extended Cab Knapheide Service Truck (A50323)
2019 Chevrolet...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
