Loose Joystick -FIXED !
/ Loose Joystick -FIXED ! #1
KiotiKevin
Port Morien, N.S., Canada
Kioti NX4510
Once again - problem solved thanks to all who posted and Tractorbynet.com. I removed the seat and the 2 bolts that hold in the Joystick box and your right, it was a bugger getting that boot lifted. For those of you who have to do this, there is a lip on the rubber that is tucked under the bottom edge of the box. I used a 22mm wrench to tighten the brass nut and it was only a very slight tug on the wrench, as a posters have said, be careful the assembly is only made of plastic.
Thanks again - Happy tractoring !
Kevin
/ Loose Joystick -FIXED ! #2
Happy to hear you fixed it without any issues.
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
John Deere Forks (A64126)
John Deere Forks...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A65643)
1994 SHOP MADE...
(10) Field Cultivator Shanks (A65640)
(10) Field...
