Loose Cutter on Disk Harrow
/ Loose Cutter on Disk Harrow #1
have_blue
Veteran Member
Eunice, Louisiana
L4400
After investigating a lot of whanging and banging noise, I discovered a loose cutter on my disk harrow.
The harrow is a light duty King Kutter 66" model with 4 groups of 4 cutters. The cutters are 16", and scalloped. The loose one is held on by a large flange at the end of the shaft. At the other end is a large nut, which I tried tightening to no avail. None of the other cutters are loose. The shafts all have a bit of play in them, but not a lot.
How should I approach tightening this cutter? Nothing appears to be broken. (There was no manual with the harrow, which I bought new).
Thanks,,,
/ Loose Cutter on Disk Harrow #2
I've seen this on big farm disks. I think one of the risks of letting it run loose is that the loose blade can break off--just at the perimeter of the flange holding it!
I'd suggest taking the weight off the blades, back the nut off a little, then if you can reach the opposite end, WHACK it with a big sledge hammer. Then try to re-tighten.
As I recall, the nuts are castle nuts, where they have a key in them to keep them from backing off. I don't recall that they might be left hand threads, but maybe that's something to check also.
I know we used hammers and punches to try to take up the last little bit.
I guess another option would be to load it on a trailer and haul it to a truck stop. Let them try to tighten it with their biggest air impact.
Hope this helps.
Ron
/ Loose Cutter on Disk Harrow #3
All that wobbling has probably ruined the thread where the nut is. You might have to take the shaft out and have a machine shop rethread it for you unless you have the die. This may be true for the other 3 gangs too. Put never seize on the threads and get the nut as tight as possible.
/ Loose Cutter on Disk Harrow #4
That's not at all uncommon. Try some heat on the nut to see if it'll break loose. If it won't tighten, take it off, and put a thick flat washer behind it, then re-tighten. Use an impact wrench if available. They need to be VERY tight. Use a BIG pipe wrench to keep the axle from turning while tightening (or loosening for that matter)
/ Loose Cutter on Disk Harrow #5
I'm wondering why just one loose one, and why the rest of the 'blades' on that axle are also not loose. /forums/images/graemlins/confused.gif
If I understand it right, I'd remoe the nut on the axle, and inspect each one of the blades and the 'dumb-bell' or dog bone separating the blades, as well as the bearings.
Seems to me something is not right that only 'one' blade is loose. I suspect a broken part and/or a failed bearing or spacer. But running it loose is not a good plan. /forums/images/graemlins/wink.gif
/ Loose Cutter on Disk Harrow #6
Indyfarmer is right! My brain more fully engaged and I remembered that we usually took the nut off, installed a flat washer, slathered the shaft in grease (it was before never-seize reached we'uns in the country!) and tighten.
The threads could be completely rusted or galled behind the nut, so the washer gives you a second chance.
Ron
Thanks for all the replies!
The nut was fairly tight, and I tightened it more. (It's a plain right hand nut, not a castle nut).
I wonder if the center of the loose disk is already broken out. I bet it is. Otherwise (as someone mentioned), why wasn't the whole gang loose?
I'll get to the bottom of it. I'll wait for a cool rainy day, get my air tools after it, and dismantle the whole works.
If it's broken, I hope I can find a replacement cutter!
/ Loose Cutter on Disk Harrow #8
Replacement cutters should be easy to find. Make sure the replacement is at least at thick as the one coming off. I replaced all of my front gangs with some that seemed to be twice as thick. It appeared to cut better with the extra weight.
/ Loose Cutter on Disk Harrow #9
Usually easy to see a broke center, the axle may be gouged. I've built mine up with mild steel rods and ground flush good as new. Then buff all mating surfaces on each pan/spacer clean before reassembling. You'll never get a tight fit otherwise and have recurring problems. (The spacers should spin axle, not the pans)
The nut probably has folding lock tabs that aren't much good. I replaced original nut with Nylock and Loctite243. then set entire gang down on a length of 2X4 and use a 6ft cheater. No problems last 2 seasons.
/ Loose Cutter on Disk Harrow #10
Let's see, we had an old Case disk harrow on the farm when I was a kid that we rebuilt more times than I care to remember. I think once you get a chance to get the weight off and pull the nut off the end, you will find that it is a square shaft. The reason the other cutters are "tight" is because they fit right on the shaft. The end one usually rides on a bearing with a square shoulder to hold the cutter so it will turn with the gang. If it has loosened up, most likely the cutter has slipped off the shoulder and that is why there is excessive play (and the noise). It really doesn't have to loosen up much for this to happen, as the thickness of the disk aren't that much and may not seem possible by visual inspection.
Anyway, hope all it needs is to be tightened and not replaced.
You said you don't have a manual, but any way you might get a copy of a parts page to help see what you have there?
Good luck and hope this helps.
Tim
/ Loose Cutter on Disk Harrow #11
Is that the unit with sealed bearings.. or the one with grey iron bearings?
If you are lucky.. the drive shaft is fine.. nd the square opening onthe disc flange has rounded out. Either way it needs to be fixed, as it will grove the shaft if it spins freely.
Soundguy
SoundGuy,
It was a cheapie, so I doubt it had sealed bearings. At any rate, it certainly doesn't have them now! /forums/images/graemlins/smile.gif
We have some cloudy weather moving in in a day or 2, and I can work on it without having a heat stroke. I'll take my great big ballast stump off the unit and pull that axle and let y'all know what I found. I've got a feeling it won't be pretty.
I guess I can run without that cutter for a little while until I lay hands on a new cutter or axle as the case may be.
http://webpages.charter.net/bobad/stump.jpg
Solved the mystery!
The center broke out of the cutter. No damage to the axle at all. I simply fitted the broken part back in like a puzzle and put it on one of the center positions where the flanges are large enough to cover the broken out center. It should last until I can get another cutter.
It all sounds so easy, but it was a real pain in the posterior. Although I used penetrating oil, I still wrung off 2 of the 1/2" carriage bolts that held the bearings to the axles. Every darn bolt galled, and every nut was hard to take off. The square heads on the carriage bolts all stripped, and I had to snap Vice Grips on them. The VG's kept un-snapping... well, you get the picture. Guess there's no such thing as grade 8 carriage bolts to replace the dead soft junk. /forums/images/graemlins/crazy.gif
/ Loose Cutter on Disk Harrow #14
Glad you solved it.
Maybe you should have hot-wrenched the bolts off (torched)?
Ron
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
Broderson Crane (A64047)
Broderson Crane...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2006 Volvo Semi (A64047)
2006 Volvo Semi...
2024 John Deere 4044R Tractor (A63116)
2024 John Deere...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
